I am doing a study on roll cages using strain gauges and I had to use an HX711 chip.
I have found code that is supposed to gather data from The strain gauge through the HX711 but for my application, I require to have 2 strain gauges taking readings at a time.
Can someone help me change that code I found to be used for 2 sensors labelled Sensor 1 and Sensor 2? Below is the code.
I don't know if HX711 library allows more than one instance of itself to be launched - not all libraries are designed for this.
But if it does, you need to connect two HX711 modules each to their own pins:
