HX711 load sell and SD Card Datalogger problem
Hi . I am building model rocket engine test stand on base HX711 load sell.The code work perfect on Serial monitor and I able to collect data. But having laptop close to the stand is risky and dangerous. That why
I want to add SD card to the project to log on to it. Since my programing skills ar very poor I hope that someone is gona help me fix the code. This is my skech.
#include <SPI.h>
#include <SD.h>
#include "HX711.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
const int chipSelect = 10;
const int buttonPin = A2;      // start sequence button
const int ledPin = A3;        //LED indicator and/or buzzer
const int igniterPin = A1;   //igniter transistor circuit
int buttonState = 0;
const int DOUT = 3;
const int CLK = 2;
HX711 scale(DOUT,CLK);
float calibration_factor = -204; //-560 works for my 10kg loadcell.
File myFile;
  pinMode(buttonPin, INPUT);
  pinMode(igniterPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  Serial.println("HX711 Rocket Motor Dynamometer, V.5");
  Serial.println("Affix motor nozzle up. Place igniter in nozzle. Move away from test stand.");
  Serial.println("Press start button to initialize ignition sequence.");
  Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {// see if the card is present and can be initialized:
  Serial.println("Card failed, or not present");
  // don't do anything more:
  return;
  Serial.println("card initialized.");
  // Create/Open file
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("  MODEL ROCKET");
  lcd.setCursor(0,1);
  lcd.print("  DYNAMOMETER");
  delay(2000);
  scale.set_scale(10);
  scale.tare(10); //Reset the scale to 0
  long zero_factor = scale.read_average(); //Get a baseline reading
  Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
  Serial.println(zero_factor);
  Serial.println(" ");
  myFile = SD.open("test.txt", FILE_WRITE);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("  Rocket Dyno");
  lcd.setCursor(0,1);
  lcd.print("  STDBY " );
  scale.set_scale(calibration_factor);
  lcd.print(scale.get_units(),1);
  lcd.print(" g");
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.setCursor(0,1);
     lcd.print("  STAND CLEAR!");
     Serial.println("IGNITION SEQUENCE ACTIVATED!");
     for (int i=0; i <= 50; i++){
       digitalWrite(ledPin, HIGH);
       delay (100);
       digitalWrite (ledPin,LOW);
       delay (100);
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.setCursor(1,1);
     lcd.print(" AQUIRING DATA");
     digitalWrite(igniterPin, HIGH);
     Serial.print("Start time, ms: ");
     Serial.print (millis());
     for (int i=0; i <= 800; i++){        //800 samples at 80sa/sec = 10 seconds theoretical
     scale.set_scale(calibration_factor); //Adjust to the calibration factor
     Serial.print(scale.get_units(), 1);
     myFile.print (scale.get_units(), 1);
     myFile.close();
     Serial.print("Stop Time, ms: ");
     Serial.print(millis());
     digitalWrite (igniterPin,LOW);
Use one of the included example to make sure your hardware aka SD card board is working right.
