Hi, im using an ESP32 38 pins dev board. I tried using and hx711 load cell amplifier which is powered by a 5V. This 5v is also connected to the esp32. The sck and dt are connected with a voltage divider setup. The wires going to the hx711 is around 120cm. I double and even tripled checked the wires. The behavior is sometimes it works then sometimes it is not . How do i deal with this? Let me know if you need more info. Thanks
Extra info so people can help you:
- Code posted in code tags
- Serial monitor output also posted in code tags
- Schematic
- Photo of the wiring
Please explain what it does when it's working and in what way it doesn't work.
“Sometimes it produces the results I expect then sometimes it does not”.
What results do you expect? Under what conditions?
I built a scale for measuring the coffee beans I grind for our coffee. It works as expected. Give more info especially serial output of relevant debug data in code tags.
