HX711 periodically "not found"
I'm using the "Basic Example" from Bogdan Necula HX711 library.
Periodically I receive a "HX711 not found." on the serial monitor. The measurement outputs every second.
I'm using a Pro Mini at 5V & 16Mhz.
Has anyone else noticed a similar situation? Or do I need to again check my connections?
Thanks
John
Good Luck. Without a schematic or code it is like saying what time is it somewhere that is dark. I have not come across any problems with Bogdan Necula HX711 library. May I assume you checked your connections and they are good? I do not know what connections go to what or what are the value of the pull up resistors etc are so I cannot really give a valid guess. Posting a schematic, not a frizzy picture of how you have wired it would be great. Also post links to "Technical" information on each of the hardware devices.
This is exactly the info I was looking for. Thanks :slight_smile:
