Greetings.
I have working HX711 and loadcell 1kg. No problem there.. i use GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales. library.
Problem is that if device restarts and i have for example 200gms load on scale... shows after restart weight 0kg.. but i would like even if you restart that weight would be same as before restart.
So i would like to somehow set scale to "remember" value of load after reset. Is that possible?
can we store the Tare/Offset values in EEPROM and use it in loop wherever required?
