hx711 to condition work
hi guys
i am using at the end a load cell with the hx711
#include <HX711_ADC.h>
//HX711 constructor (dout pin, sck pin)
HX711_ADC LoadCell(8, 9);
long t;
  Serial.begin(250000);
  Serial.println("Wait...");
  LoadCell.begin();
  long stabilisingtime = 4000; // tare preciscion can be improved by adding a few seconds of stabilising time
  LoadCell.start(stabilisingtime);
  LoadCell.setCalFactor(696.0); // user set calibration factor (float)
  Serial.println("Startup + tare is complete");
  //update() should be called at least as often as HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS
  //longer delay in scetch will reduce effective sample rate (be carefull with delay() in loop)
  LoadCell.update();
  //get smoothed value from data set + current calibration factor
  if (millis() > t + 20) {
    float i = LoadCell.getData();
    Serial.print("Load_cell output val: ");
    Serial.println(i);
    t = millis();
  //receive from serial terminal
  if (Serial.available() > 0) {
    float i;
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay();
  //check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
along integrated with my own code
i can serial read the values and it works good
the problem is once i want to use those values to give a condition the “i” used in serial print to display the value doesnt work for me
  if (failsafe> 65 and gear < 95 and (here has to be the hx711 output vale, i have used "i" with no success) > 220 and pot >= 0 and pot <= 25 )
all the other values are in range and work fine, once i want to give it the condition lets say…if wheight is more than … do this… as shown in the part code above.
how can i do this?
thank you for reading
Please post the complete code you are having problems with please?
Try using && instead of and
https://www.arduino.cc/reference/en/language/structure/boolean-operators/logicaland/
the code is this
int QS = A2;         //coil
int failsafe;    //failsafe
int pot;              //for mapping function
int clutch ;          //for mapping function
HX711_ADC LoadCell(4, 5);
long t;
pinMode (QS, OUTPUT);
pinMode (failsafe, INPUT);
pinMode (pot, INPUT);
pinMode (clutch, INPUT);
  LoadCell.begin();
  long stabilisingtime = 2000; // tare preciscion can be improved by adding a few seconds of    stabilising time
  LoadCell.update();
  if (millis() > t + 250) {
    Serial.println(i);
    t = millis();
    float i;
  if (clutch > 65 and failsafe < 95 and i > 225 and pot >= 0 and pot <= 25 )
                 digitalWrite (QS, LOW),
                 delay (90),
                 digitalWrite (QS, HIGH),
                 delay (60);
the hx711 code prints the obtained vaule to serial monitor, i need to use the given value to condition the action if it goes past a point
Did you read post#1 about your "and" functions?
Tom..... :slight_smile:
