Hello
Watch a video of a digital scale with Arduino that includes calibration, but does not include the button. Only you can add it to this program because you don't use the normal sentences from the HX711 book.
I hope I can help you with this!
LiquidCrystal_I2C lcd(0x27,16,2);
// Se declaran los pines a utilizar
#define DT A0
#define SCK A1
#define sw 9
#define tarar 8
// Se declaran las variables a utilizar
long sample=0;
float val=0;
long count=0;
unsigned long readCount(void)
unsigned long Count;
unsigned char i;
pinMode(DT, OUTPUT);
digitalWrite(DT,HIGH);
digitalWrite(SCK,LOW);
Count=0;
pinMode(DT, INPUT);
while(digitalRead(DT));
for (i=0;i<24;i++)
digitalWrite(SCK,HIGH);
Count=Count<<1;
if(digitalRead(DT))
Count++;
Count=Count^0x800000;
return(Count);
pinMode(SCK, OUTPUT);
pinMode(sw, INPUT_PULLUP);
lcd.init();
lcd.backlight();
lcd.print(" Medicion ");
lcd.setCursor(0,1);
lcd.print(" de peso ");
lcd.clear();
calibrate();
//tare (); // Le agregué la función de tara
// Sección de impresion de peso
count= readCount();
float w=(((count-sample)/val)-2*((count-sample)/val))/10; //Cambie el tipo int por float para tener mas decimales
lcd.setCursor(0,0);
lcd.print("Peso");
lcd.setCursor(0,1);
lcd.print(w);
lcd.print("Kg ");
if(digitalRead(sw)==0)
val=0;
sample=0;
w=0;
count=0;
calibrate();
// Sección de calibración
void calibrate()
lcd.clear();
lcd.print("Calibrando...");
lcd.setCursor(0,1);
lcd.print("Por favor espere...");
for(int i=0;i<100;i++)
count=readCount();
sample+=count;
sample/=100;
lcd.clear();
lcd.print("Ponga 10Kg");
lcd.setCursor(0,1);
lcd.print("y espere");
count=0;
while(count<1000)
count=readCount();
count=sample-count;
lcd.clear();
delay(2000);
count=readCount();
val+=sample-count;
val=val/10000.0; // Pon aquí tu peso de calibración
lcd.clear();
