I am experiencing a touch coordinate misalignment issue with my 3.5” TFT 320x480 touchscreen manufactured by Adafruit. When setting up and testing using an Arduino mega 2560 the display worked fine but the touch sensor does not.
I am using the device in SPI mode using the following connections:
Linked 3V3 to IM2 on TFT to select SPI mode
TFT Pin : ATMega PIN
VIN : 5V
GND : GND
CLK : D52
MISO : D50
MOSI : D51
CS : D10
DC : D9
RST : RESET
X- : A1
Y- : 7
X+ : 6
Y+ : A0
Below is the Arduino Code Script that I am using
#define THERMO_CS 8
#define SSR_PIN 2
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST -1 // RST can be set to -1 if you tie it to Arduino's reset
// Note the X and Y pin numbers are opposite from what is printed on the TFT display. This was done to align with the screen rotation.
#define YP A0 // must be an analog pin, use "An" notation!
#define XM A1 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 6 // can be a digital pin
// This is calibration data for the raw touch data to the screen coordinates
//#define TS_MINX 190
//#define TS_MINY 400
//#define TS_MAXX 890
//#define TS_MAXY 820
#define TS_MINX 250 // From bottom-left X (rounded from 248)
#define TS_MAXX 680 // From top-left X (rounded from 679)
#define TS_MINY 160 // From top-left Y (rounded from 162)
#define TS_MAXY 880 // From bottom-right Y (rounded from 874)
#include <PID_v1.h>
#include <Adafruit_MAX31856.h>
#include <SPI.h>
#include "Adafruit_GFX.h"
#include <Fonts/FreeMonoBold12pt7b.h>
#include <Fonts/FreeMonoBold18pt7b.h>
#include "Adafruit_HX8357.h"
#include <stdint.h>
#include "TouchScreen.h"
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// SoftSPI - note that on some processors this might be *faster* than hardware SPI!
//Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, SOFT_MOSI, SOFT_CLK, TFT_RST, SOFT_MISO);
const int displayWidth = 480, displayHeight = 320;
const int gridSize = 80;
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
TSPoint touchpoint = ts.getPoint();
bool setupMenu = false, editMenu = false, reflowMenu = false;
const int touchHoldLimit = 500;
// use hardware SPI, just pass in the CS pin
Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(THERMO_CS);
// Use software SPI: CS, DI, DO, CLK
//Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(THERMO_CS, SOFT_MOSI, SOFT_MISO, SOFT_CLK);
unsigned long timeSinceReflowStarted;
unsigned long timeTempCheck = 1000;
unsigned long lastTimeTempCheck = 0;
double preheatTemp = 180, soakTemp = 150, reflowTemp = 230, cooldownTemp = 25;
unsigned long preheatTime = 120000, soakTime = 60000, reflowTime = 120000, cooldownTime = 120000, totalTime = preheatTime + soakTime + reflowTime + cooldownTime;
bool preheating = false, soaking = false, reflowing = false, coolingDown = false, newState = false;
uint16_t gridColor = 0x7BEF;
uint16_t preheatColor = HX8357_RED, soakColor = 0xFBE0, reflowColor = 0xDEE0, cooldownColor = HX8357_BLUE; // colors for plotting
uint16_t preheatColor_d = 0xC000, soakColor_d = 0xC2E0, reflowColor_d = 0xC600, cooldownColor_d = 0x0018; // desaturated colors
// Define Variables we'll be connecting to
double Setpoint, Input, Output;
// Specify the links and initial tuning parameters
double Kp=2, Ki=5, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
while (!Serial)
delay(10);
Serial.println("Solder Reflow Oven");
delay(100);
tft.begin();
tft.setRotation(1);
tft.fillScreen(HX8357_BLACK);
tft.setCursor(0,0);
tft.setTextSize(1);
if (!maxthermo.begin()) {
Serial.println("Could not initialize thermocouple.");
while (1) delay(10);
maxthermo.setThermocoupleType(MAX31856_TCTYPE_K);
Serial.print("Thermocouple type: ");
switch (maxthermo.getThermocoupleType() ) {
case MAX31856_TCTYPE_B: Serial.println("B Type"); break;
case MAX31856_TCTYPE_E: Serial.println("E Type"); break;
case MAX31856_TCTYPE_J: Serial.println("J Type"); break;
case MAX31856_TCTYPE_K: Serial.println("K Type"); break;
case MAX31856_TCTYPE_N: Serial.println("N Type"); break;
case MAX31856_TCTYPE_R: Serial.println("R Type"); break;
case MAX31856_TCTYPE_S: Serial.println("S Type"); break;
case MAX31856_TCTYPE_T: Serial.println("T Type"); break;
case MAX31856_VMODE_G8: Serial.println("Voltage x8 Gain mode"); break;
case MAX31856_VMODE_G32: Serial.println("Voltage x8 Gain mode"); break;
default: Serial.println("Unknown"); break;
maxthermo.setConversionMode(MAX31856_ONESHOT_NOWAIT);
Setpoint = cooldownTemp;
// tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, 1);
// turn the PID on
myPID.SetMode(AUTOMATIC);
pinMode(SSR_PIN, OUTPUT);
digitalWrite(SSR_PIN,LOW);
///* Setup Menu *///
drawSetupMenu();
setupMenu = true;
Serial.println("Setup Menu");
while(setupMenu){
if(touchpoint.z > ts.pressureThreshhold){
int setupMenuXPos = getGridCellX(), setupMenuYPos = getGridCellY();
Serial.print("Setup menu touch: ("); Serial.print(setupMenuXPos); Serial.print(","); Serial.print(setupMenuYPos); Serial.print(") -> ");
if(setupMenuYPos < 3){ // Somewhere other than the start button
editMenu = true;
bool editingPreheat = false, editingSoak = false, editingReflow = false;
if(setupMenuXPos < 2 ){ // Somwhere within the preheat zone
editingPreheat = true;
tft.fillScreen(preheatColor);
Serial.println("Edit Preheat Menu");
drawEditMenu("Preheat");
centerText(2,0,1,1,HX8357_WHITE,String(int(preheatTemp)));
centerText(5,0,1,1,HX8357_WHITE, formatTime(preheatTime));
else if(setupMenuXPos > 3 ){// Somwhere within the reflow zone
editingReflow = true;
tft.fillScreen(reflowColor);
Serial.println("Edit Reflow Menu");
drawEditMenu("Reflow");
centerText(2,0,1,1,HX8357_WHITE,String(int(reflowTemp)));
centerText(5,0,1,1,HX8357_WHITE, formatTime(reflowTime));
else{ // Somwhere within the soak zone
editingSoak = true;
tft.fillScreen(soakColor);
Serial.println("Edit Soak Menu");
drawEditMenu("Soak");
centerText(2,0,1,1,HX8357_WHITE,String(int(soakTemp)));
centerText(5,0,1,1,HX8357_WHITE, formatTime(soakTime));
while(editMenu){// Stay in this loop until the save button is pressed
int editMenuXPos = getGridCellX(), editMenuYPos = getGridCellY();
Serial.print("Edit menu touch at ("); Serial.print(editMenuXPos); Serial.print(","); Serial.print(editMenuYPos); Serial.print(") -> ");
if(editMenuYPos == 1){ // One of the up arrows was pressed
if(editMenuXPos < 3){ // The Temp up arrow was pressed
Serial.println("Temp up arrow");
tft.fillRoundRect(2*gridSize+2, 0*gridSize+2, gridSize-4, gridSize-4, 10, HX8357_BLACK);
if(editingPreheat){
if(preheatTemp < 300);
preheatTemp += 10;
if(editingSoak){
if(soakTemp < 300);
soakTemp += 10;
if(editingReflow){
if(reflowTemp < 300);
reflowTemp += 10;
else{// The Time up arrow was pressed
Serial.println("Time up arrow");
tft.fillRoundRect(5*gridSize+2, 0*gridSize+2, gridSize-4, gridSize-4, 10, HX8357_BLACK);
if(editingPreheat){
if(preheatTime < 300000)
preheatTime += 10000;
if(editingSoak){
if(soakTime < 300000)
soakTime += 10000;
if(editingReflow){
if(reflowTime < 300000)
reflowTime += 10000;
else if(editMenuYPos == 2){// One of the down arrows was pressed
if(editMenuXPos < 3){ // The Temp down arrow was pressed
Serial.println("Temp down arrow");
if(editingPreheat){
if(preheatTemp > 100)
preheatTemp -= 10;
if(editingSoak){
if(soakTemp > 100)
soakTemp -= 10;
if(editingReflow){
if(reflowTemp > 100)
reflowTemp -= 10;
else{// The Time down arrow was pressed
Serial.println("Time down arrow");
if(editingPreheat){
if(preheatTime > 30000)
preheatTime -= 10000;
else if(editingSoak){
if(soakTime > 30000)
soakTime -= 10000;
else if(editingReflow){
if(reflowTime > 30000)
reflowTime -= 10000;
else if(editMenuYPos == 3){ // Save button was pressed
Serial.println("Save button");
drawSetupMenu();
editMenu = false;
delay(touchHoldLimit); // so holding the button down doesn't read multiple presses
else{// Start button was pressed
Serial.println("Start button");
setupMenu = false;
///* Reflow Menu *///
drawReflowMenu();
drawButton(0,3,2,1, HX8357_GREEN, HX8357_WHITE, "Start");
bool start = false;
while(!start){
if(getGridCellX() <2 && getGridCellY() == 3){
start = true;
drawButton(0,3,2,1, HX8357_RED, HX8357_WHITE, "Stop");
Serial.println("Reflow Menu");
unsigned long reflowStarted = millis();
reflowMenu = true;
while(reflowMenu){
timeSinceReflowStarted = millis() - reflowStarted;
if(timeSinceReflowStarted - lastTimeTempCheck > timeTempCheck){
lastTimeTempCheck = timeSinceReflowStarted;
printState();
// check for conversion complete and read temperature
if (maxthermo.conversionComplete()) {
Serial.print("\tSetpoint:"); Serial.print(Setpoint);
Input = maxthermo.readThermocoupleTemperature();
Serial.print("\tInput:"); Serial.print(Input);
myPID.Compute();
if(Output < 0.5){
if(Output > 0.5){
digitalWrite(SSR_PIN,HIGH);
Serial.print("\tOutput:"); Serial.println(Output);
plotDataPoint();
else {
Serial.println("\tConversion not complete!");
// trigger a conversion, returns immediately
maxthermo.triggerOneShot();
if(timeSinceReflowStarted > totalTime){
reflowMenu = false;
else if(timeSinceReflowStarted > (preheatTime + soakTime + reflowTime)){ // preheat and soak and reflow are complete. Start cooldown
if(!coolingDown){
newState = true;
preheating = false, soaking = false, reflowing = false, coolingDown = true;
else if(timeSinceReflowStarted > (preheatTime + soakTime)){ // preheat and soak are complete. Start reflow
if(!reflowing){
newState = true;
preheating = false, soaking = false, reflowing = true, coolingDown = false;
Setpoint = reflowTemp;
else if(timeSinceReflowStarted > preheatTime){ // preheat is complete. Start soak
if(!soaking){
newState = true;
preheating = false, soaking = true, reflowing = false, coolingDown = false;
Setpoint = soakTemp;
else{ // cycle is starting. Start preheat
if(!preheating){
newState = true;
preheating = true, soaking = false, reflowing = false, coolingDown = false;
Setpoint = preheatTemp;
if(getGridCellX() < 2 && getGridCellY() == 3){
reflowMenu = false;
drawButton(0,3,2,1, HX8357_GREEN, HX8357_WHITE, "Done");
bool done = false;
while(!done){
done = true;
void printState(){
String time = formatTime(timeSinceReflowStarted);
Serial.print("Current time: "); Serial.print(time); Serial.print("\t");
tft.fillRoundRect(5*gridSize+2, 3*gridSize+2, gridSize-4, gridSize-4, 10, HX8357_BLACK);
centerText(5,3,1,1,0,HX8357_WHITE,time);
centerText(5,3,1,1,2,HX8357_WHITE,String(Input));
String currentState;
if(preheating){
currentState = "Preheating";
if(soaking){
currentState = "Soaking";
if(reflowing){
currentState = "Reflowing";
if(coolingDown){
currentState = "Cool Down";
Serial.print(currentState);
if(newState){
newState = false;
tft.fillRoundRect(2*gridSize+2, 3*gridSize+2, 2*gridSize-4, gridSize-4, 10, HX8357_BLACK);
centerText(2,3,2,1,HX8357_WHITE,currentState);
void drawGrid(){
tft.setFont();
tft.setTextColor(HX8357_WHITE);
tft.drawRect(0,0,displayWidth,displayHeight-gridSize,gridColor);
for(int i=1; i<6; i++){
tft.drawFastVLine(i*gridSize,0,displayHeight-gridSize,gridColor);
for(int j=1; j<4; j++){
tft.drawFastHLine(0,j*gridSize,displayWidth,gridColor);
tft.setCursor(4,4); tft.print("300");
tft.setCursor(4,1*gridSize+4); tft.print("200");
tft.setCursor(4,2*gridSize+4); tft.print("100");
tft.setCursor(1*gridSize+4,3*gridSize-7-4); tft.print(formatTime(totalTime/6));
tft.setCursor(2*gridSize+4,3*gridSize-7-4); tft.print(formatTime(2*totalTime/6));
tft.setCursor(3*gridSize+4,3*gridSize-7-4); tft.print(formatTime(3*totalTime/6));
tft.setCursor(4*gridSize+4,3*gridSize-7-4); tft.print(formatTime(4*totalTime/6));
tft.setCursor(5*gridSize+4,3*gridSize-7-4); tft.print(formatTime(5*totalTime/6));
plotReflowProfile();
void drawButton(int x, int y, int w, int h, uint16_t backgroundColor, uint16_t textColor, String text){
tft.setFont(&FreeMonoBold12pt7b);
if(backgroundColor == HX8357_BLACK){
tft.drawRoundRect(x*gridSize+2, y*gridSize+2, w*gridSize-4, h*gridSize-4, 10, HX8357_WHITE);
else{
tft.fillRoundRect(x*gridSize+2, y*gridSize+2, w*gridSize-4, h*gridSize-4, 10, backgroundColor);
if(text == "UP_ARROW"){
tft.fillTriangle(x*gridSize+(w*gridSize-60)/2, y*gridSize+(h*gridSize-52)/2+52, x*gridSize+(w*gridSize-60)/2+60, y*gridSize+(h*gridSize-52)/2+52, x*gridSize+w*gridSize/2, y*gridSize+(h*gridSize-52)/2, textColor);
else if(text == "DOWN_ARROW"){
tft.fillTriangle(x*gridSize+(w*gridSize-60)/2, y*gridSize+(h*gridSize-52)/2, x*gridSize+(w*gridSize-60)/2+60, y*gridSize+(h*gridSize-52)/2, x*gridSize+w*gridSize/2, y*gridSize+(h*gridSize-52)/2+52, textColor);
else{
int16_t textBoundX, textBoundY;
uint16_t textBoundWidth, textBoundHeight;
tft.getTextBounds(text,0,0,&textBoundX, &textBoundY, &textBoundWidth, &textBoundHeight);
tft.setCursor(x*gridSize+(w*gridSize-textBoundWidth)/2, y*gridSize+(h*gridSize+textBoundHeight)/2); tft.setTextColor(textColor); tft.print(text);
void centerText(int x, int y, int w, int h, uint16_t textColor, String text){
void centerText(int x, int y, int w, int h, int justification, uint16_t textColor, String text){
switch(justification){
case 0: //top justified
tft.setCursor(x*gridSize+(w*gridSize-textBoundWidth)/2, y*gridSize+(h*gridSize/2-textBoundHeight)/2+textBoundHeight);
case 1: //center justified
case 2: //bottom justified
tft.setCursor(x*gridSize+(w*gridSize-textBoundWidth)/2, y*gridSize+gridSize-(h*gridSize/2-textBoundHeight)/2);
void drawSetupMenu(){
drawButton(0,0,2,3, preheatColor, HX8357_WHITE, ""); drawButton(2,0,2,3, soakColor, HX8357_WHITE, ""); drawButton(4,0,2,3, reflowColor, HX8357_WHITE, "");
centerText(0,0,2,1, HX8357_WHITE, "Preheat"); centerText(2,0,2,1, HX8357_WHITE, "Soak"); centerText(4,0,2,1, HX8357_WHITE, "Reflow");
centerText(0,1,2,1,0, HX8357_WHITE, String(int(preheatTemp)) + " C"); centerText(2,1,2,1,0, HX8357_WHITE, String(int(soakTemp)) + " C"); centerText(4,1,2,1,0, HX8357_WHITE, String(int(reflowTemp)) + " C");
centerText(0,1,2,1,2, HX8357_WHITE, String(formatTime(preheatTime)) + " min."); centerText(2,1,2,1,2, HX8357_WHITE, String(formatTime(soakTime)) + " min.");centerText(4,1,2,1,2, HX8357_WHITE, String(formatTime(reflowTime)) + " min.");
drawButton(0,3,6,1, HX8357_GREEN, HX8357_WHITE, "Confirm");
tft.drawCircle(90,95,3,HX8357_WHITE); tft.drawCircle(250,95,3,HX8357_WHITE); tft.drawCircle(410,95,3,HX8357_WHITE);
void drawReflowMenu(){
drawGrid();
centerText(4,3,1,1,0, HX8357_WHITE, "Time: ");
centerText(4,3,1,1,2, HX8357_WHITE, "Temp: ");
//drawButton(0,3,2,1, HX8357_RED, HX8357_WHITE, "Stop"); drawButton(0,3,2,1, HX8357_RED, HX8357_WHITE, "Start");
void drawEditMenu(String stage){
centerText(0,0,2,1,0, HX8357_WHITE, stage); centerText(0,0,2,1, HX8357_WHITE, " Temp: "); drawButton(0,1,3,1, HX8357_WHITE, HX8357_BLACK, "UP_ARROW"); drawButton(0,2,3,1, HX8357_WHITE, HX8357_BLACK, "DOWN_ARROW");
centerText(3,0,2,1,0, HX8357_WHITE, stage); centerText(3,0,2,1, HX8357_WHITE, " Time: "); drawButton(3,1,3,1, HX8357_WHITE, HX8357_BLACK, "UP_ARROW"); drawButton(3,2,3,1, HX8357_WHITE, HX8357_BLACK, "DOWN_ARROW");
//centerText(0,1,2,1,0, HX8357_WHITE, String(int(preheatTemp))); //centerText(2,1,2,1,0, HX8357_WHITE, String(int(soakTemp))); centerText(4,1,2,1,0, HX8357_WHITE, String(int(reflowTemp)));
//centerText(0,1,2,1,2, HX8357_WHITE, String(formatTime(preheatTime))); //centerText(2,1,2,1,2, HX8357_WHITE, String(formatTime(soakTime)));centerText(4,1,2,1,2, HX8357_WHITE, String(formatTime(reflowTime)));
//drawButton(0,0,2,2, HX8357_BLACK, HX8357_WHITE, ""); drawButton(2,0,2,2, HX8357_BLACK, HX8357_WHITE, ""); drawButton(4,0,2,2, HX8357_BLACK, HX8357_WHITE, "");
//drawButton(0,2,1,1, HX8357_WHITE, HX8357_BLACK, "UP");drawButton(1,2,1,1, HX8357_WHITE, HX8357_BLACK, "DOWN");
//drawButton(2,2,1,1, HX8357_WHITE, HX8357_BLACK, "UP");drawButton(3,2,1,1, HX8357_WHITE, HX8357_BLACK, "DOWN");
//drawButton(4,2,1,1, HX8357_WHITE, HX8357_BLACK, "UP");drawButton(5,2,1,1, HX8357_WHITE, HX8357_BLACK, "DOWN");
drawButton(0,3,6,1, HX8357_GREEN, HX8357_WHITE, "Save");
int getGridCellX(){
int xpoint = touchpoint.x;
Serial.print("x resistance: ");Serial.print(xpoint); Serial.print(" ");
//xpoint = map(xpoint,TS_MINX,TS_MAXX,displayWidth-1,0);
if(xpoint > 824)
return 0;
else if(xpoint > 689)
return 1;
else if(xpoint > 546)
return 2;
else if(xpoint > 399)
return 3;
else if(xpoint > 259)
return 4;
return 5;
int getGridCellY(){
int ypoint = touchpoint.y;
Serial.print("y resistance: ");Serial.print(ypoint); Serial.print(" ");
//ypoint = map(ypoint,TS_MINY,TS_MAXY,0,displayHeight-1);
if(ypoint > 800)
return 3;
else if(ypoint > 690)
return 2;
else if(ypoint > 500)
return 1;
return 0;
String formatTime(unsigned long milliseconds) {
// Calculate the number of minutes and seconds
unsigned long totalSeconds = milliseconds / 1000;
unsigned int minutes = totalSeconds / 60;
unsigned int seconds = totalSeconds % 60;
// Format the time as a string with a leading zero if necessary
String formattedTime = (minutes < 10 ? "0" : "") + String(minutes) + ":" + (seconds < 10 ? "0" : "") + String(seconds);
return formattedTime;
/*int mapTime(int time){
return map(time,0,totalTime,0,displayWidth);
/*int mapTemp(int temp){
return map(temp,0,300,3*gridSize,0);
void plotDataPoint(){
uint16_t color;
if(preheating){
color = preheatColor;
if(soaking){
color = soakColor;
if(reflowing){
color = reflowColor;
if(coolingDown){
color = cooldownColor;
tft.fillCircle(map(timeSinceReflowStarted,0,totalTime,0,displayWidth),map(Input,0,300,3*gridSize,0),2, color);
//tft.fillCircle(mapTime(timeSinceReflowStarted), mapTemp(Input), 2, color);
void plotReflowProfile(){
int xMin, xMax, amp;
xMin = 0;
xMax = map(preheatTime,0,totalTime,0,displayWidth);
amp = map(preheatTemp,0,300,3*gridSize,0) - map(cooldownTemp,0,300,3*gridSize,0);
for(int i = 0; i <= (xMax-xMin); i++){
tft.fillCircle(xMin+i,-amp/2*cos(PI*i/(xMax-xMin))+map(cooldownTemp,0,300,3*gridSize,0)+amp/2,2,preheatColor_d);
xMin = map(preheatTime,0,totalTime,0,displayWidth);
xMax = map(preheatTime+soakTime,0,totalTime,0,displayWidth);
amp = map(soakTemp,0,300,3*gridSize,0) - map(preheatTemp,0,300,3*gridSize,0);
//amp = 80;
tft.fillCircle(xMin+i,-amp/2*cos(PI*i/(xMax-xMin))+map(preheatTemp,0,300,3*gridSize,0)+amp/2,2, soakColor_d);
xMin = map(preheatTime+soakTime,0,totalTime,0,displayWidth);
xMax = map(preheatTime+soakTime+reflowTime,0,totalTime,0,displayWidth);
amp = map(reflowTemp,0,300,3*gridSize,0) - map(soakTemp,0,300,3*gridSize,0);
//amp = 80;
tft.fillCircle(xMin+i,-amp/2*cos(PI*i/(xMax-xMin))+map(soakTemp,0,300,3*gridSize,0)+amp/2,2,reflowColor_d);
xMin = map(preheatTime+soakTime+reflowTime,0,totalTime,0,displayWidth);
xMax = map(totalTime,0,totalTime,0,displayWidth);
amp = map(cooldownTemp,0,300,3*gridSize,0) - map(reflowTemp,0,300,3*gridSize,0);
//amp = 80;
tft.fillCircle(xMin+i,-amp/2*cos(PI*i/(xMax-xMin))+map(reflowTemp,0,300,3*gridSize,0)+amp/2,2, cooldownColor_d);
