Hybird bi-polar stepper motor
Hello,
I'm hoping that someone here would be generous with their time and help me with my problem.
I am trying to operate a hybird bipolar stepper motor through a "motor sensor" connected to a Camera Axe.
This setup controls a normal bipolar stepper motor just fine but when I hook up a hybird one the motor buzzes and when I activate it the motor movements are erratic and jerks around in both directions. I have tried every possible arrangement of cable connection.
Is this board able to operate this type of motor? Do I have to modify the board?
Here are the schematics of the Camera Axe shield and motor sensor.
Here is the manual for the motor.
http://www.phidgets.com/documentation/Phidgets/3318_0_Product_Manual.pdf
Thank you to anyone who can help me with this, I am very new to the arduino platform and stepper motors.
If I'm missing any info that can help you help me please ask and I will do whatever I can to provide the answers.
It's the correct type of motor. 2 possible problems -
You don't have the motor connected correctly to the driver. Check you wiring for loose connections.
You don't have the correct voltage/current or you need to have a longer acceleration time.
You are trying to move the motor too fast (can be a voltage or current problem)
Thank you for your reply!
I will test out the speed when I get home.
Would that also account for the loud buzzing when powered on? The buzzing goes away when the motor is activated.
I am using a 12v lithium battery to power the driver.
Changing the speed does not help. I've also hooked up 2 other hybird motors and they all behave the same. I have no idea what to try next.
Does anyone have any ideas for what else I can try or what the problem might be?
You say that you can get a regular bipolar (4 wires) working but not a hybrid bipolar ( 4 wires ) .
Hook up the regular one and get it working. Make a note of the wiring. Remove the wiring and measure the resistance with an ohmmeter between the wires. With a 4 wire stepper there are 2 sets of "coils" which will show some resistance between 2 wires which indicates a "coil".
Don't have an ohmmeter? Well you might be able to identify the "coil" by spinning the stepper by hand and touching 2 wires together. If you feel resistance then those 2 wires form a "coil".
Now identify the "coils" on your hybrid. Hook them up the same way as the regular one to the board.
Thank you for the tip, I will try that.
