I am trying to interface a hydrophone (PHOD-1) with an Arduino. Any idea how I should go about this? The output signal from the hydrophone is AC coupled to the built in pre amp input with 6db attenuation. The output signal will start to clip at 8V peak to peak and about 2.8V RMS.
maybe any hints of what kind of circuitry i need to build before i connect them to the analog input of the Arduino.
The maximum rate that the Arduino can sample an audio input is about 9.6 kHz with full 10 bit resolution and about 38 kHz with 8 bits resolution. That, plus the Nyquist criterion, limits audio signal processing to the highest audio frequencies of 4.8 kHz (10 bits) or 19 kHz (8 bits). Of course at those highest frequencies the sampling rate gives you the minimum possible representation of the input waveform, so with very low fidelity.
