Hallo,
ich habe bei Conrad den HYT 271 gekauft.
Zunächst wollte ich den Sensor auf Funktionsfähigkeit prüfen mit den im Internet stehenden Codes, jedoch habe ich immer seltsame konstante Werte ausgespuckt bekommen "99.99% - temp: -40.01"
Ich habe vermutet das die standardmäßige I2C Adresse geändert wurde (0x28) und habe den in der playground i2c-scanner benutzt, um die richtige i2c-adresse rauszufinden.
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 0x01; address < 0x7F; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
Jetzt kommt das nächste Problem : der Scanner sagt :
"Scanning...No I2C devices found"
das heißt also entweder ich habe es falsch angeschlossen oder das teil ist kaputt oder?
Ich habs auf dem Duemilanove und auf einem Uno probiert.
Angeschlossen wurde es wie folgt:
HYT 271 -> Arduino
SDA->A4
GND->GND
VDD-> 3,3V und 5 V (beides ausprobiert)
SCL->A5
