Hysteresis
else if (val0 = 0)
I doubt you meant that. An assignment statement evaluates to the assigned value. '0' will never be true. '==' perhaps?
gfvalvo, true that == is what should be there. thanks
You also have two variables named 'val0'. One global, one local. It may not be your problem, but it's really poor coding style.
Yes, i spotted that, this is due to that different option we run across so at some stage things get mixed up
#include "U8glib.h"
#include <OneWire.h>
#include <DallasTemperature.h>
int anPin0 = A0;
int anPin1 = A1;
int val0 = 0;
int val1 = 0;
int oldvalue = 0;
byte hysteresis = 1;
// Create a Onewire Referenca and assign it to pin 10 on your Arduino
OneWire oneWire(10);
// declare as sensor referenec by passing oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// declare your device address
// YOUR ADDRESS GOES HERE!!!!
DeviceAddress tempSensor = {0x28, 0xFF, 0x2B, 0x45, 0x4C, 0x04, 0x00, 0x10};
// A Variable to hold the temperature you retrieve
float tempC;
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0 | U8G_I2C_OPT_NO_ACK | U8G_I2C_OPT_FAST); // Fast I2C / TWI
void draw(void) {
  // graphic commands to redraw the complete screen should be placed here
  // Water Temp Left Head
  u8g.setFont(u8g_font_10x20);
  u8g.setPrintPos(0, 35);
  u8g.print("TEMP:");
  u8g.setPrintPos(50, 35);
  u8g.print(val0);
  u8g.setPrintPos(105, 35);
  u8g.setFont(u8g_font_5x8);
  u8g.print("Left");
  if (val1 > 100)
    u8g.drawCircle(83, 22, 1.5);
    u8g.setPrintPos(85, 35);
    u8g.print("C");
  else if (val1 > 10)
    u8g.drawCircle(73, 22, 1.5);
    u8g.setPrintPos(75, 35);
    u8g.print("C");
  else if (val1 < 10)
    u8g.drawCircle(63, 22, 1.5);
    u8g.setPrintPos(65, 35);
    u8g.print("C");
  // Water Temp Right Head
  u8g.setPrintPos(0, 60);
  u8g.print("TEMP:");
  u8g.setPrintPos(50, 60);
  u8g.print(val0);
  u8g.setPrintPos(105, 60);
  u8g.print("Right");
    if (val1 > 100)
    u8g.drawCircle(83, 47, 1.5);
    u8g.setPrintPos(85, 60);
    u8g.print("C");
  else if (val1 > 10)
    u8g.drawCircle(73, 47, 1.5);
    u8g.setPrintPos(75, 60);
    u8g.print("C");
  else if (val1 < 10)
    u8g.drawCircle(63, 47, 1.5);
    u8g.setPrintPos(65, 60);
    u8g.print("C");
  // Eng Oil Pressure
  u8g.setPrintPos(0, 15);
  u8g.print("OIL:");
  u8g.setPrintPos(50, 15);
  u8g.print(val1); // change when you add pressure sensor
  if (val1 > 100)
    u8g.setPrintPos(83, 8);
    u8g.print("Psi");
  else if (val1 > 10)
    u8g.setPrintPos(73, 8);
    u8g.print("Psi");
  else if (val1 < 10)
    u8g.setPrintPos(63, 8);
    u8g.print("Psi");
void setup(void) {
  // start serial port
  // set the resolution to 9 bit - Valid values are 9, 10, or 11 bit.
  sensors.setResolution(tempSensor, 9);
  // confirm that we set that resolution by asking the DS18B20 to repeat it back
  Serial.print("Sensor Resolution: ");
  Serial.println(sensors.getResolution(tempSensor), DEC);
  // flip screen, if required
  // u8g.setRot180();
void loop(void)
  // Tell the Sensor to Measure and Remember the Temperature it Measured
  sensors.requestTemperaturesByAddress(tempSensor); // Send the command to get temperatures
  // Get the temperature that you told the sensor to measure
  tempC = sensors.getTempC(tempSensor);
  // Serial.print("Temp C: ");
  // Serial.print(tempC,4);  // The four just increases the resolution that is printed
  // Serial.print(" Temp F: ");
  // The Dallas Temperature Control Libray has a conversion function... we'll use it
  // Serial.println(DallasTemperature::toFahrenheit(tempC),4);
  // delay(1000);
  val0 = analogRead(anPin0);
  val1 = analogRead(anPin0);
  Serial.print(val0);
  Serial.print(" ");
  Serial.println(val1);
  val0 = map(val0, 0, 1023, 0, 120);
  val1 = map(val1, 0, 1023, 0, 150);
  if (oldvalue != val0)
    if (val0  > oldvalue + hysteresis or val0  < oldvalue - hysteresis)
      (oldvalue = (val0 - 1));
      updateOled();
    else if (val0 == 0)
      oldvalue = 0;
      updateOled();
  delay(100);
void updateOled(void)
{ // picture loop
  u8g.firstPage();
  do {
    draw();
  } while ( u8g.nextPage() );
