avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/10666854/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/home/10666854/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/ttyACM0": No such file or directory
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Board at /dev/ttyACM0 is not available
Can anyone help me with this please i am facing this error a lot of time and the code was for PS4 Controller code is:
#include <Keyboard.h> // Use built-in Keyboard library
#include <HID_Buttons.h> // Must import AFTER Keyboard.h
#include <Mouse.h>
const uint8_t Pin_XAxis = A0; // Pin for joy horizontal axis
const uint8_t Pin_YAxis = A1; // Pin for joy vertical axis
const int JoyCenter = 1023 / 2; // max value for 10-bit ADC / 2
const int JoyDeadzone = 50; // +/- area around the center to ignore
int horzPin = A2; // Analog output of horizontal joystick pin
int vertPin = A3; // Analog output of vertical joystick pin
int selPin = 9; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 200; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
//int invertMouse = 1; //Invert joystick based on orientation
int invertMouse = -1; //Noninverted joystick based on orientation
KeyboardButton moveForward('W');
KeyboardButton moveLeft('A');
KeyboardButton moveBackward('S');
KeyboardButton moveRight('D');
Keyboard.begin();
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
Mouse.begin(); //Init mouse emulation
int x = analogRead(Pin_XAxis); // Read X axis
int y = analogRead(Pin_YAxis); // Read Y axis
moveLeft.set(x < JoyCenter - JoyDeadzone);
moveRight.set(x > JoyCenter + JoyDeadzone);
moveForward.set(y < JoyCenter - JoyDeadzone);
moveBackward.set(y > JoyCenter + JoyDeadzone);
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if ()
if (vertValue != 0)
Mouse.move(0, (invertMouse * (vertValue / sensitivity)), 0); // move mouse on y axis
if (horzValue != 0)
Mouse.move((invertMouse * (horzValue / sensitivity)), 0, 0); // move mouse on x axis
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
Serial.println("Joystick button is clicked");
else if ((digitalRead(selPin)) && (mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
Serial.println("Joystick button is released");
i also got another error newly:
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port '/dev/ttyACM0'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - /dev/ttyACM0; Method name - openPort(); Exception type - Permission denied.
at jssc.SerialPort.openPort(SerialPort.java:170)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
