I am Arduino NANO and the code is stuck on uploading and shows error
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\mudit\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x9d
I am using new bootloader and blink sketch with no pins attached to arduino
Is COM3 the correct port?
Have you tried the other two options in IDE menu tools -> processor?
yes i have tried both processor and the COM port is coorect
In that case I don't know :frowning:
Looks like problem with serial speed.
Try the old bootloader option with 57600 baud.
In case the problem will persist: Which Nano exactly?
