the whole wireless thing is becoming more and more common. I expect that in a few years, the internet of things will have more of an established backbone.
I would look at creating a wireless module that could be placed inside of, or next to, an electrical switch box.
in the US, we have duplex receptacles, these can be separated so you can have one that is switched and one that is powered constantly.
as has been noted, the space inside of a switch box is at a premium and there is little spare room for boards. however, if you look at a dimmer, the enclosure is deeper than a receptacle. and if you buy one specific receptacle, you could bring out terminal connectors that could be screwed directly on to the screws so that they are both electrical connections and mounting connections. then have your board attached.
if you look at switch boxes, there are deep boxes that accommodate more space for wire nuts and the like. there are a few that have a side box area that is hidden.
I would offer that there a 39 cent receptacles that have a very slim contact point for your plug and there are spec. grade that have a much larger surface area in contact. often over $8 each so there is a lot of price difference, but you get what you pay for. much cheaper in quantity.
I also suspect that these receptacles will be available soon enough from the big players. not sure if I just come up with the idea and dropped into the public domain. if you run with this, please send me some stock in your company.
if making one, a zero cross switching would be simple enough to add and should extend the life off your board as well as the things connected.
It seems to me that with a receptacle pack, one could retrofit any house.
then, as to control. you could have a transmitter in areas of the house so that you can control your points remotely from off-site, or locally with some form of wireless.
