I am connecting a mcp4132 in attiny 85, but it does not have ss. how can I solve it?
As the device data sheet clearly explains, use /CS instead.
Sorry, I did not express myself well, attiny85 does not have ss or sc.
I'm new to this anyway and I still don't quite understand everything. The code I am using is this.
Is there a way to communicate with the mcp without the attiny85 having ss or sc?
#include <SPI.h>
int ss =  2; // slave select pins
// set SS pin directions
// Others are handled automatically
pinMode(ss, OUTPUT);
//Initialize SPI
SPI.begin();
// function to set LED to specific level
// reg is the register, register is the index - this is only one pot,
// so the reg is == 00000000
// level is the leve
void setLed(int reg, int level) {
digitalWrite(ss, LOW); // set SS to low for communicating to that chip
SPI.transfer(reg); // send register / index
SPI.transfer(level);
digitalWrite(ss, HIGH); // Finish writing to that chip
for(int i = 0; i<255; i++) {
setLed(0, i);
delay(20);
Serial.println(i);
for(int i = 255; i<=0; i--) {
setLed(0, i);
delay(20);
Serial.println(i);
The code you posted is most likely intended for a standard Arduino, and probably won't work with an ATtiny85, which does not have a separate SPI interface.
The ATtiny85 can be made to work, but you will have a much easier time getting started if you choose another processor, like the Uno, Pro Mini, Nano, etc.
You may find this helpful: ATtiny 85 and SPI
I was just reading that post and I was able to make the connection in the same way. . thank you very much for your help.
