I am creating a robot according to the code provided below and it is controlled by an app created by mit app inventor .i wanted to add record and replay functionality in it such that each actions performed by the robot the first time is recorded and is automatically replayed from the next time from a click of a button .please help there should also be a button for erasing recorded actions so that there is space for recording the next set of recordings .
#include <Servo.h>
#include <SoftwareSerial.h>
SoftwareSerial BT(A0, A1);
Servo servo_1;
Servo servo_2;
int motor_r2 = 6;
int motor_r1 = 7;
int motor_l2 = 8;
int motor_l1 = 9;
int state;
int speed = 130;
int pos1 = 90;
int pos2 = 90;
int pump = 4;
int pwm = 5;
void setup(){
servo_1.attach(2);
servo_2.attach(3);
servo_1.write(pos1);
servo_2.write(pos2);
pinMode(motor_l1, OUTPUT);
pinMode(motor_l2, OUTPUT);
pinMode(motor_r1, OUTPUT);
pinMode(motor_r2, OUTPUT);
pinMode(pump, OUTPUT);
pinMode(pwm, OUTPUT);
// initialize serial communication at 9600 bits per second:
BT.begin(9600); // Setting the baud rate of Software Serial Library
void loop(){
//if some date is sent, reads it and saves in state
if(BT.available() > 0){
state = BT.read();
Serial.println(state);
if(state > 15){speed = state;}
// if the state is '1' the DC motor will go forward
if (state == 1){forword();Serial.println("Forward!");}
// if the state is '2' the motor will Backword
else if (state == 2){backword();Serial.println("Backword!");}
// if the state is '3' the motor will turn left
else if (state == 3){turnLeft();Serial.println("Turn LEFT");}
// if the state is '4' the motor will turn right
else if (state == 4){turnRight();Serial.println("Turn RIGHT");}
// if the state is '5' the motor will Stop
else if (state == 5) {stop();Serial.println("STOP!");}
else if (state == 6) {Serial.println("lift"); if(pos1<180){pos1 = pos1+1;}}
else if (state == 7) {Serial.println("right"); if(pos1>0){pos1 = pos1-1;}}
else if (state == 8) {Serial.println("up"); if(pos2>0){pos2 = pos2-1;}}
else if (state == 9) {Serial.println("down"); if(pos2<180){pos2 = pos2+1;}}
else if (state == 10){Serial.println("pump on");digitalWrite(pump, HIGH);}
else if (state == 11){Serial.println("pump off");digitalWrite(pump, LOW);}
analogWrite(pwm, speed);
delay(30);
void stop(){
digitalWrite(motor_l1, LOW);
digitalWrite(motor_l2, LOW);
digitalWrite(motor_r1, LOW);
digitalWrite(motor_r2, LOW);
void forword(){
digitalWrite(motor_l2, HIGH);
digitalWrite(motor_r1, HIGH);
void backword(){
digitalWrite(motor_l1, HIGH);
digitalWrite(motor_r2, HIGH);
void turnRight(){
void turnLeft(){
presumably you can capture commands along with a timestamp to maintain their timing. you need to decide what that capture buffer is and how buttons are processes to begin capturing, execute and reset
but there are several problems with the code you posted
Serial.read() returns an ASCII character. subtracting an ascii zero '0' results in an integer from 0-9.
reading just a single char prevents having commands > 9. perhaps use Serial.readBytesUntil() to read multiple characters and used atoi() to translate the string to an integer
the block of code that processes commands, state does so regardless of receiving a new command. so that last received command is repeatedly executed. perhaps put this block into a sub-function that is called when a new command is received and eventually to process "captured" commands
Plenty of resources on the internet. The problem becomes, which is your favorite? I like DroneBotWorkshop for record/playback of servo movement... (find "record" on page)
This is fully servo record and replay i want to record and replay gear motor and pump functions. I used a driver shield gor motors. By the way my code has changed.
//Arduino Bluetooth Controlled Car
//Before uploading the code you have to install the necessary library
//Note - Disconnect the Bluetooth Module before hiting the upload button otherwise you'll get compilation error message.
//AFMotor Library https://learn.adafruit.com/adafruit-motor-shield/library-install
//After downloading the library open Arduino IDE >> go to sketch >> Include Libray >> ADD. ZIP Libray >> Select the downloaded
//ZIP File >> Open it >> Done
//Now You Can Upload the Code without any problem but make sure the bt module isn't connected with Arduino while uploading code
#include <AFMotor.h>
#include <Servo.h>
#define pum 15
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
char command;
Servo servo1;
Servo servo2;
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
servo1.attach(10);
servo2.attach(9);
pinMode(pum, OUTPUT);
void loop(){
if(Serial.available() > 0){
command = Serial.read();
Stop(); //initialize with motors stoped
//Change pin mode only if new command is different from previous.
//Serial.println(command);
switch(command){
case 'F':
forward();
case 'B':
back();
case 'L':
left();
case 'R':
right();
case 'W':
pumpon();
case 'w':
pumpoff();
case 'U':
servoup();
case 'u':
servodown();
case 'V':
servoleft();
case 'v':
servoright();
void forward()
motor1.setSpeed(500); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(500); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(500);//Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(500);//Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.setSpeed(500); //Define maximum velocity
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.setSpeed(500); //Define maximum velocity
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
motor1.setSpeed(0); //Define minimum velocity
motor1.run(RELEASE); //stop the motor when release the button
motor2.setSpeed(0); //Define minimum velocity
motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
void pumpon(){
digitalWrite (pum, HIGH);
void pumpoff(){
digitalWrite (pum, LOW);
void servoup(){
servo2.write(0);
void servodown(){
servo2.write(100);
void servoleft(){
servo1.write(0);
void servoright(){
servo1.write(140);
