Please read and use the sticky post “How to get the best out of this forum”.
You may be able to read your screen shots but they are not readable on this end.
Try reading this: How to get the best out of this forum, it appears you have not read it at this point.
are you using STM32CubeIDE or the Arduio IDE or some other IDE?
which serial port are you attempting to connect too? e.g. Serial, Serial1, Serial2, etc
I am using Arduino Ide with Icestudio fpga software. so I am using hardware serial for my uart communication for baud rate of 115200 for 20 MHZ. So what I am trying to do is I want to connect 2 modules together so that uart communication can channel from teh white block uart core to the right side module
previously I tested this uart white block module to be working with led0 and led1 which I will be using for run and reset. but now i changed the design to not use the leds because they are connected to the fpga source code. so i wanted to route the uart signals for led0 and led1 to the fpga source code so that when i key in 0 or 1 respectively, the led0 and led1 would light up. I have checked with the oscillscope but there is no signal at the fpga ports b10 and b12. which means that the 2 modules are still not integrated yet. Is there something else that I have missed in my connections or rather do I need more assign statements for my uart white block like basically do i need to channel the data lines from my receiver and transmitter and somhow slot it in to the fpga source code by declaring new input ports?
