I am doing a project and used the NewPing library with the HC-SR04 sensor
When I verify the program, there was no error. I know all the parts for the robot such as the motors, Mini servo motor, and ultrasonic sensor are properly working. However, the program isn't executing even though the code is shown to be correct. I am also using a simple Arduino Uno board and an Adafruit Motor Shield. This is my first project on Arduino and have spent hours researching to no avail.
This is my code:
#include <AFMotor.h> //add Adafruit Motor Shield library
#include <Servo.h> //add Servo Motor library
#include <NewPing.h> //add Ultrasonic sensor library
#define TRIG_PIN A0 // Pin A0 on the Motor Drive Shield soldered to the ultrasonic sensor
#define ECHO_PIN A1 // Pin A1 on the Motor Drive Shield soldered to the ultrasonic sensor
#define MAX_DISTANCE 300 // sets maximum useable sensor measuring distance to 300cm
#define MAX_SPEED 160 // sets speed of DC traction motors to 150/250 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 40 // this sets offset to allow for differences between the two DC traction motors
#define COLL_DIST 30 // sets distance at which robot stops and reverses to 30cm
#define TURN_DIST COLL_DIST+20 // sets distance at which robot veers away from object
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
AF_DCMotor leftMotor1(1, MOTOR12_1KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor leftMotor2(2, MOTOR12_1KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
AF_DCMotor rightMotor1(3, MOTOR34_1KHZ);// create motor #3, using M3 output, set to 1kHz PWM frequency
AF_DCMotor rightMotor2(4, MOTOR34_1KHZ);// create motor #4, using M4 output, set to 1kHz PWM frequency
Servo myservo; // create servo object to control a servo
int leftDistance, rightDistance; //distances on either side
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
myservo.attach(10); // attaches the servo on pin 10 (SERVO_1 on the Motor Drive Shield to the servo object
myservo.write(90); // tells the servo to position at 90-degrees ie. facing forward.
delay(1000); // delay for one seconds
//---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
myservo.write(90); // move eyes forward
delay(90);
curDist = readPing(); // read distance
if (curDist < COLL_DIST) {changePath();} // if forward is blocked change direction
moveForward(); // move forward
void changePath() {
moveStop(); // stop forward movement
myservo.write(36); // check distance to the right
rightDistance = readPing(); //set right distance
myservo.write(144); // check distace to the left
delay(700);
leftDistance = readPing(); //set left distance
myservo.write(90); //return to center
delay(100);
compareDistance();
void compareDistance() // find the longest distance
if (leftDistance>rightDistance) //if left is less obstructed
turnLeft();
else if (rightDistance>leftDistance) //if right is less obstructed
turnRight();
else //if they are equally obstructed
turnAround();
int readPing() {
delay(70);
unsigned int uS = sonar.ping();
int cm = uS/US_ROUNDTRIP_CM;
return cm;
void moveStop() {leftMotor1.run(RELEASE); leftMotor2.run(RELEASE); rightMotor1.run(RELEASE); rightMotor2.run(RELEASE);} // stop the motors.
void moveForward() {
motorSet = "FORWARD";
leftMotor1.run(FORWARD); // turn it on going forward
leftMotor2.run(FORWARD); // turn it on going forward
rightMotor1.run(FORWARD); // turn it on going forward
rightMotor2.run(FORWARD); // turn it on going forward
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
leftMotor1.setSpeed(speedSet);
leftMotor2.setSpeed(speedSet);
rightMotor1.setSpeed(speedSet);
rightMotor2.setSpeed(speedSet);
delay(5);
void moveBackward() {
motorSet = "BACKWARD";
leftMotor1.run(BACKWARD); // turn it on going backward
leftMotor2.run(BACKWARD); // turn it on going backward
rightMotor1.run(BACKWARD); // turn it on going backward
rightMotor2.run(BACKWARD); // turn it on going backward
delay(5);
void turnRight() {
motorSet = "RIGHT";
leftMotor1.run(FORWARD); // turn motor 1 forward
leftMotor2.run(FORWARD); // turn motor 2 forward
rightMotor1.run(BACKWARD); // turn motor 3 backward
rightMotor2.run(BACKWARD); // turn motor 4 backward
rightMotor1.setSpeed(speedSet+MAX_SPEED_OFFSET);
rightMotor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
delay(1500); // run motors this way for 1500
leftMotor1.run(FORWARD); // set both motors back to forward
void turnLeft() {
motorSet = "LEFT";
leftMotor1.run(BACKWARD); // turn motor 1 backward
leftMotor2.run(BACKWARD); // turn motor 2 backward
leftMotor1.setSpeed(speedSet+MAX_SPEED_OFFSET);
leftMotor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
rightMotor1.run(FORWARD); // turn motor 3 forward
rightMotor2.run(FORWARD); // turn motor 4 forward
void turnAround() {
motorSet = "RIGHT";
delay(1700); // run motors this way for 1700
Can someone help me fix the code so I don't use the NewPing library because others say it is horrible. I attached the TrigPin to the Arduino Uno Digital Pin 10 and the echo pin to Digital output 13.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar, then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
My recommendation is to add a bunch of Serial.println() statements to your sketch, then run it with the Serial Monitor (Tools > Serial Monitor) open so that you can see what's happening with your program.
TOMTHEBIGBOY:
The code is not 'correct' until it does what you want. There are many more ways to write a sketch that compiles without error and doesn't work than a sketch that does work.
I take it from your description that the motors don't move at all?
What pins does the AF library use to control the motors ?
What I have in mind is that PWM does not work on pins 9 and 10 of a Uno when the Servo library is used.
