EVERYTHING IN THE CODE I CHECKED SEEMS TO BE CORRECT ....BUT THESE ERRORS ARE still showing up..
Arduino: 1.8.7 Hourly Build 2018/09/12 02:23 (Windows 10), Board: "Arduino/Genuino Uno"
sketch_mar25a:10:3: error: variable or field 'setup' declared void
sketch_mar25a:10:21: error: expected ')' before ';' token
sketch_mar25a:11:2: error: 'myservo' does not name a type
myservo.attach(9); //Servo control
sketch_mar25a:12:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(2,OUTPUT); //Motor driver pin 1
sketch_mar25a:13:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(3,OUTPUT); //Motor driver pin 2
sketch_mar25a:14:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(4,OUTPUT); //Motor driver pin 3
sketch_mar25a:15:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(5,OUTPUT); //Motor driver pin 4
sketch_mar25a:16:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(6,OUTPUT); //Ultrasonic Trigger
sketch_mar25a:17:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(7,INPUT); //Ultrasonic Echo
sketch_mar25a:18:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(8,OUTPUT); //Laser
sketch_mar25a:19:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(10,OUTPUT); //LED
sketch_mar25a:20:9: error: expected constructor, destructor, or type conversion before '(' token
pinMode(A0, INPUT); //LDR
sketch_mar25a:21:2: error: 'laserstatus' does not name a type
laserstatus="OFF";
sketch_mar25a:22:2: error: 'servoangle' does not name a type
servoangle=90;
sketch_mar25a:23:2: error: 'myservo' does not name a type
myservo.write(servoangle);
sketch_mar25a:24:2: error: 'recordstatus' does not name a type
recordstatus="NotRecording";
sketch_mar25a:25:2: error: 'requiredrecordstatus' does not name a type
requiredrecordstatus="StopRecording";
sketch_mar25a:26:2: error: 'fr' does not name a type
fr=0;
sketch_mar25a:27:2: error: 'br' does not name a type
br=0;
sketch_mar25a:28:2: error: 'sr' does not name a type
sr=0;
sketch_mar25a:29:2: error: 'rr' does not name a type
rr=0;
sketch_mar25a:30:2: error: 'lr' does not name a type
lr=0;
sketch_mar25a:31:2: error: 'i' does not name a type
i=0;
sketch_mar25a:32:2: error: expected unqualified-id before 'for'
for(int c=0;c<20;c++)
sketch_mar25a:32:14: error: 'c' does not name a type
sketch_mar25a:32:19: error: 'c' does not name a type
sketch_mar25a:42:3: error: expected unqualified-id before ')' token
exit status 1
option enabled in File -> Preferences.
