I am getting a error code and i dont know why!
My error code is 'ping_cm' was not declared in this scope
The highlighted piece of code is this "if (ping_cm > 7) {"
I have included my code below
The idea is that when item gets within a curtain range of the ultrasonic sensor it will send a signal and turn on a led and no matter what, When i try to compile it I get that error code. Please help
I am using 2 arduino wifis and i know that the sensor is wired correctly
This is the sender code.
Thank you
#include <WiFiNINA.h>
#include <NewPing.h>
#define SONAR_NUM 1      // Number of sensors.
#define MAX_DISTANCE 30 // Maximum distance (in cm) to ping.
NewPing sonar[SONAR_NUM] = {   // Sensor object array.
  NewPing(3, 2, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
char ssid[] = "Netcomm 3240";
char pass[] = "Ninazoyope";
int status = WL_IDLE_STATUS;
char server[] = "10.0.1.16";
WiFiClient client;
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(10000);
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
    for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through each sensor and display results.
    delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
    Serial.print("cm");
    Serial.print("=");
    Serial.print(sonar[i].ping_cm());
    Serial.print("cm ");
    if (ping_cm > 7) {
    if (client.connect(server, 80)) {
      Serial.println("connected");
      client.println("GET /red HTTP/1.0");
      client.println();
  } else
      client.println("GET /green HTTP/1.0");
      client.println();
    Serial.println("problem");
// ---- TO HERE
  if (client.connected()) {
    client.stop();
ping_cm is a member of the sonar structure (sonar[i].ping_cm()). It makes no sense to use ping_cm by itself.
What are you trying to do there. Find if any distance measured by the array of sonars is > 7?
its just 1 sensor that im using and a few weeks ago (with some code that i lost) i made it so that only using ping_cm it would trigger something...
I am trying to figure out if one sensor detects something that is over 7 cm
  if (ping_cm > 7) {
Aren't you looking for
if (sonar[i].ping_cm() > 7)
Where in your code i == 1.
Tom... :grinning: :+1: :coffee:
Error "I was not delcared in this scope
ping_cm() is not declared
BUT
sonar[i].ping_cm() is declared.
You are not using ping_cm(), you are using sonar[i].ping_cm() because you are setup for more than one sonar unit.
Tom... :grinning: :+1: :coffee: :australia:
i only lives (is in scope) in the for loop. Once the for loop completes i no longer exists.
You have only one element in the sonar array so use
if (sonar[0].ping_cm() > 7)
Why do you even declare an array if it has only one element?
i am kinda mashing together code that i found online into my project. It also now gives the error code "Expected unqulified-id before 'else'"
Post the code.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
Sender_garage:57:5: error: expected unqualified-id before 'else'
} else
Sender_garage:63:3: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
Post the code.
WiFiClient client;
    delay(10000);
  Serial.println(ip);
    Serial.print("cm");
    Serial.print("=");
      client.println();
    } else //I GET THE ERROR HERE
      client.println();
// ---- TO HERE
    client.stop();
Wait
Thats a entire new error
Sorry
Nothing to do with the first one
please still help thou
Use the IDE autoformat tool (ctrl-t or Tools, Auto format). You should see where you have 2 extra curly brackets.
That curly bracket is extra.
So is the first one on that line.
You can simplify a bit since y9ou are only using one ultrasonic sensor:
NewPing sonar(3, 2, MAX_DISTANCE);
WiFiClient client;
    delay(10000);
  Serial.println(ip);
  Serial.print("cm");
  Serial.print("=");
  Serial.print(sonar.ping_cm());
    if (sonar.ping_cm() > 7)
    client.println();
    Serial.println("problem: Client didn't connect");
    client.stop();
