I am getting the information below, not really an error
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\gabby\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM10
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\gabby\AppData\Local\Temp\arduino_build_798902/HelloWorld.ino.hex"
avrdude: writing flash (1894 bytes):
Writing | ################################################## | 100% 0.35s
avrdude: 1894 bytes of flash written
avrdude: verifying flash memory against C:\Users\gabby\AppData\Local\Temp\arduino_build_798902/HelloWorld.ino.hex:
avrdude: load data flash data from input file C:\Users\gabby\AppData\Local\Temp\arduino_build_798902/HelloWorld.ino.hex:
avrdude: input file C:\Users\gabby\AppData\Local\Temp\arduino_build_798902/HelloWorld.ino.hex contains 1894 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.27s
avrdude: verifying ...
avrdude: 1894 bytes of flash verified
avrdude done. Thank you.
Can anyone please help with this result I am getting after up-loading a program. Thanks in advance.
It provides information regarding:
The programming software authors and version.
The memory that is being programmed.
The name of the program being uploaded and the size.
At the end it shows:
This is a good thing.
Now I'm going to guess what I wrote is no more useful than the original message. The truth is you must read up on the At328P processor and understand what flash, links etc are.
To expand on JohnRob's answer: this is the output from a successful upload. Sometimes it worries people because it is shown in red in the Arduino IDE's console, but this output means everything is working correctly with the compilation and upload process.
But surely there is a lot of interesting information there, so perhaps you are only intending to learn more about it?
Thank you, but that does not answer the question. I sent "hello world" to the Arduino LCD and I am not getting it, therefore, how do I get my "hello world."
Post the code you are having problems with so we can see where the problem may be. Also a schematic or simple drawing of how you connected the LCD, and which 328P based Arduino you are using.
Thank you, but I need to see my data that is sent from my computer to the Arduino. Thanks again.
So the message "hello world" is being sent from your computer to your Arduino which is then supposed to display it on an LCD?
You will get more support from the community if you explain what you are trying to do, what hardware you are using, how you have wired it up, what code you have written etc.
Okay, I will do that
