I am getting this error while i connect esp 32 wroom and ov7670 camera. Anyone here can provide me the solution for this?
ELF file SHA256: 0000000000000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
Initialized core board!
Contents of buf_out:
65
66
67
Preparing to do I2C Write
Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x00000000 PS : 0x00060a30 A0 : 0x800d1264 A1 : 0x3ffb27d0
A2 : 0x3ffb27fc A3 : 0x3ffc1280 A4 : 0x3ffb27f9 A5 : 0x00000003
A6 : 0x00000001 A7 : 0x00000000 A8 : 0x800d11b3 A9 : 0x3ffb27b0
A10 : 0x3ffb2784 A11 : 0x3ffb27f9 A12 : 0x00000003 A13 : 0x00061a80
A14 : 0x3ffb7e50 A15 : 0x00000000 SAR : 0x00000010 EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000 LBEG : 0x400865b9 LEND : 0x400865c9 LCOUNT : 0xfffffffa
Backtrace:0xfffffffd:0x3ffb27d00x400d1261:0x3ffb27f0 0x400d2845:0x3ffb28
Rebooting...
entry 0x400805f0
65
66
67
This does not sound like a problem with IDE 2.x and hence your topic has been moved to a more suitable location on the forum.
I'm not familiar with the boards that you use and can't help further. It might however help others to help you if you post your sketch (don't forget the code tags as describe in https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966#posting-code-and-common-code-problems and a wiring diagram.
PS John Wasser is no longer active on the forum.
Please do not post the same question twice. I've merged your topics.
ok i will take care of it
