I am having an error
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:uPesy_wroom --build-cache-path /tmp --output-dir /tmp/2910988330/build --build-path /tmp/arduino-build-F27D94EA05010993F5311E08938A1E0A /tmp/2910988330/Untitled_jan13a
/home/builder/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /tmp/arduino-build-F27D94EA05010993F5311E08938A1E0A/sketch/objs.a(Untitled_jan13a.ino.cpp.o):(.literal._Z14initPropertiesv+0x44): undefined reference to `onLedStateChange()'
collect2: error: ld returned 1 exit status
Multiple libraries were found for "WiFi.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFi
Not used: /home/builder/opt/libraries/nina_wi_fi_1_0_1
Not used: /home/builder/opt/libraries/da16200_wi_fi_library_for_arduino_1_1_0
Not used: /home/builder/opt/libraries/seeed_arduino_rpcwifi_1_0_6
Not used: /home/builder/opt/libraries/indhilib_3_0_5
Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
Not used: /home/builder/opt/libraries/wifinina_1_8_14
Not used: /home/builder/opt/libraries/wifi_1_2_7
Not used: /home/builder/opt/libraries/wifiespat_1_4_3
Multiple libraries were found for "WiFiClientSecure.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFiClientSecure
Multiple libraries were found for "Adafruit_Sensor.h"
Used: /home/builder/opt/libraries/adafruit_unified_sensor_1_1_14
Not used: /home/builder/opt/libraries/arduav_1_4_2
Multiple libraries were found for "Wire.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/Wire
Not used: /home/builder/opt/libraries/flexwire_1_1_2
Multiple libraries were found for "DHT.h"
Used: /home/builder/opt/libraries/dht_kxn_3_4_4
Not used: /home/builder/opt/libraries/dht118266_1_0_16
Not used: /home/builder/opt/libraries/dht11esp8266_1_0_10
Not used: /home/builder/opt/libraries/nanoplayboard_0_1_1
Not used: /home/builder/opt/libraries/dht_sensor_library_1_4_6
Not used: /home/builder/opt/libraries/dht11esp8266examples_1_0_10
Not used: /home/builder/opt/libraries/servodht11_1_0_10
Not used: /home/builder/opt/libraries/ukit_explore_1_2_28
Not used: /home/builder/opt/libraries/grove_temperature_and_humidity_sensor_2_0_1
Not used: /home/builder/opt/libraries/esp826611_1_0_16
Error during build: exit status 1
what should I do?
