I am having trouble getting attachInterrupt to work.
Hello, I am having trouble getting attachInterupt to work on an Arduino nano.
I am trying to catch the change of state of an encoder when it is turned, not read the encoder.
CLK pin of the encoder is attached to D3.
A0 goes to a transistor, in order to ground a pin on a sound board.
The sound circuit works when sent 5 volts manually.
I have been through multiple references and tutorials, I don't know what I'm doing wrong.
Here is the code, //********** indicates code related to the problem.
Thanks for any help.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN  150
#define SERVOMAX  600
#define USMIN  600
#define USMAX  2400
#define SERVO_FREQ 50
   uint8_t servonum = 0;
   const int buttonPinstockext = 12;
   const int buttonPinstockret = 11;
   const int buttonPinbarrelext = 8;
   const int buttonPinbarrelret = 7;
   const int buttonPinencodeclick = 9;
   const int interruptpin = 3; //**************************************************************
   int buttonStatestockext = 0;
   int buttonStatestockret = 0;
   int buttonStatebarrelext = 0;
   int buttonStatebarrelret = 0;
   int buttonStateencodeclick = 0;
   volatile int encodeturn = 0;//*************************************************************
   pinMode(buttonPinstockext, INPUT);
   pinMode(buttonPinstockret, INPUT);
   pinMode(buttonPinbarrelext, INPUT);
   pinMode(buttonPinbarrelret, INPUT);
   pinMode(buttonPinencodeclick, INPUT);
   pinMode(interruptpin, INPUT);//***********************************************************
   attachInterrupt(digitalPinToInterrupt(interruptpin), beep, CHANGE);//*********************
   pinMode(A0, OUTPUT);//********************************************************************
   pinMode(A1, OUTPUT);
   pinMode(A2, OUTPUT);
   pinMode(A3, OUTPUT);
   pinMode(A6, OUTPUT);
   pinMode(A7, OUTPUT);
  digitalWrite(A0, LOW);//******************************************************************
  digitalWrite(A1, LOW);
  digitalWrite(A2, LOW);
  digitalWrite(A3, LOW);
  digitalWrite(A6, LOW);
  digitalWrite(A7, LOW);
  pwm.begin();
  pwm.setOscillatorFrequency(27000000);
  pwm.setPWMFreq(SERVO_FREQ);  // Analog servos run at ~50 Hz updates
  delay(10);
void setServoPulse(uint8_t n, double pulse)
  double pulselength;
  pulselength = 1000000;
  pulselength /= SERVO_FREQ;
  pulselength /= 4096;
  pulse *= 1000000;
  pulse /= pulselength;
  pwm.setPWM(n, 0, pulse);
void beep()//*******************************************************************************
  encodeturn = 1;                                    //*************************************
 buttonStateencodeclick = digitalRead(buttonPinencodeclick);
 buttonStatestockext = digitalRead(buttonPinstockext);
 buttonStatestockret = digitalRead(buttonPinstockret);
 buttonStatebarrelext = digitalRead(buttonPinbarrelext);
 buttonStatebarrelret = digitalRead(buttonPinbarrelret);
 if (encodeturn == 1);//********************************************************************
  digitalWrite(A0, LOW);                             //*************************************
  delay(130);                                        //*************************************
  digitalWrite(A0, HIGH);                            //*************************************
  encodeturn = 0;                                    //*************************************
 if ((buttonStatestockext == HIGH) || (buttonStatestockret == HIGH))
    pwm.setPWM(7, 0, 0);
 if ((buttonStatebarrelext == HIGH) || (buttonStatebarrelret == HIGH))
    pwm.setPWM(6, 0, 0);
 if ((buttonStateencodeclick == LOW) && (buttonStatestockext == HIGH))
    pwm.setPWM(7, 0, 240);
 if ((buttonStateencodeclick == LOW) && (buttonStatebarrelext == HIGH))
    pwm.setPWM(6, 0, 275);
 if ((buttonStateencodeclick == LOW) && (buttonStatestockret == HIGH))
    pwm.setPWM(7, 0, 340);
 if ((buttonStateencodeclick == LOW) && (buttonStatebarrelret == HIGH))
    pwm.setPWM(6, 0, 320);
Remove the semicolon from after the conditional statement. It makes everything after the statement execute whether it is true or not.
Thank You so much, that worked. The sound is now triggered when I turn the encoder.
