i am having trouble merging these two sketches together
Sketch 1:
  AirQuality Demo V1.0.
  connect to A0 to start testing. it will needs about 20s to start
* By: http://www.seeedstudio.com
#include"AirQuality.h"
#include"Arduino.h"
AirQuality airqualitysensor;
int current_quality =-1;
    airqualitysensor.init(14);
    current_quality=airqualitysensor.slope();
    if (current_quality >= 0)// if a valid data returned.
        if (current_quality==0)
            Serial.println("High pollution! Force signal active");
        else if (current_quality==1)
            Serial.println("High pollution!");
        else if (current_quality==2)
            Serial.println("Low pollution!");
        else if (current_quality ==3)
            Serial.println("Fresh air");
ISR(TIMER1_OVF_vect)
	if(airqualitysensor.counter==61)//set 2 seconds as a detected duty
			airqualitysensor.last_vol=airqualitysensor.first_vol;
			airqualitysensor.first_vol=analogRead(A0);
			airqualitysensor.counter=0;
			airqualitysensor.timer_index=1;
			PORTB=PORTB^0x20;
		airqualitysensor.counter++;
Sketch 2:
#include <LiquidCrystal.h>
int Contrast=20;
 LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
    analogWrite(6,Contrast);
     lcd.begin(16, 2);
     lcd.setCursor(0, 0);
     lcd.print("Air Quality Sensor");
    lcd.setCursor(0, 1);
     lcd.print("Open Serial Monitor");
I have tried many ways and still having trouble. I would really like to have this project done soon.
You have a sketch that does something. You did not bother saying what it actually does.
You have another sketch that does something. You did not bother saying what it actually does.
You want to create another sketch that does something. You did not bother saying what you want the resulting program to do. You did not bother posting your attempt to create that program. Nor did you explain what the attempt actually does (if it even compiles) or how that differed from what you actually wanted it to do.
Best get busy, then.
Merged fine for me:
int current_quality = -1;
int Contrast = 20;
  analogWrite(6, Contrast);
  lcd.begin(16, 2);
  current_quality = airqualitysensor.slope();
    if (current_quality == 0)
    else if (current_quality == 1)
    else if (current_quality == 2)
    else if (current_quality == 3)
  if (airqualitysensor.counter == 61) //set 2 seconds as a detected duty
    airqualitysensor.last_vol = airqualitysensor.first_vol;
    airqualitysensor.first_vol = analogRead(A0);
    airqualitysensor.counter = 0;
    airqualitysensor.timer_index = 1;
    PORTB = PORTB ^ 0x20;
johnwasser:
Merged fine for me:
int Contrast = 20;
  lcd.begin(16, 2);
      Serial.println(“High pollution! Force signal active”);
      Serial.println(“High pollution!”);
      Serial.println(“Low pollution!”);
      Serial.println(“Fresh air”);
  lcd.print(“Air Quality Sensor”);
  lcd.print(“Open Serial Monitor”);
I tried later and got this
Air Quality Sensor
#include"Arduino.h"
int Contrast=20;
     lcd.begin(16, 2);
     lcd.print("Air Quality");
     lcd.print("Sensor");
			PORTB=PORTB^0x20;
it seems to work but the numbers are very different
what would be more accurate? its an air quality sensor
More accurate than what? What do you have? What do you want it to do? What accuracy are you expecting?
