I AM SO FRUSTRATED I DONT UNDERSTAND WHY EVERYTHING FAILSSSSSSSSSSSSSSSSSSSSSSSS
I AM WORKING WITH THE DS3231 MODULE, AND IVE GOT THE LIBRARY AS WELL AS wire.h BUT IT WONT STOP TELLING ME THAT THE gettime function doesnt exist??????????????????????????????????????????????????????????????????
Please post your full sketch.
If possible, you should always post code directly in the forum thread as text using code tags:
  • Do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code. This will make it easier for you to spot bugs and make it easier for us to read.
  • In the Arduino IDE or Arduino Web Editor, click on the window that contains your sketch code.
  • Press “Ctrl + A”. This will select all the text.
  • Press “Ctrl + C”. This will copy the selected text to the clipboard.
  • In a forum reply here, click the “Reply” button.
  • click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the sketch between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Repeat the above process if your sketch has multiple tabs.
This will make it easy for anyone to look at it, which will increase the likelihood of you getting help.
If the sketch is longer than the 9000 characters maximum allowed by the forum, then it’s OK to add it as an attachment. After clicking the “Reply” button, you will see an “Attachments and other settings” link that will allow you to make the attachment.
When your code requires a library that’s not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
  • When you encounter an error, you’ll see a button on the right side of the orange bar “Copy error messages” in the Arduino IDE (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button…
  • In a forum reply here, click on the reply field.
  • Press “Ctrl + V”. This will paste the error between the code tags.
If the text exceeds the forum’s 9000 character limit, save it to a .txt file and post it as an attachment. If you click the “Reply” button here, you will see an “Attachments and other settings” link that will allow you to make the attachment.
We're frustrated, too. Why does nobody ever Read this before posting a programming question.
YELLING at the forum is a guarantee of few responses.
Which Library have you included in your sketch for DS3231 RTC Module?
and is it the gettime function, or the getTime function?
It is very frustrating when you grab a sketch from the Internet and they don't say which of the MANY DS3231 libraries thy used. There are FOURTEEN libraries that show up when you search Library Manager for "DS3231". Sometimes your best bet is to do a Google search for DS3231 and gettime. That MIGHT lead you to the one library that was used in the sketch you are trying to compile.
