I am tearing my heir out over MIDI!
I can not get my Arduino to play my keyboards through MIDI :frowning: I've done it before but it just won't work now.
So I am a bit embarrased to ask but I'm desperate...
I've tried multiple keyboards (and checked by running a keyboard off another through MIDI) and multiple arduinos (diecimila 168 and Mini Pro 328 16MHz).
I've wired according to this diagram:
I have tried to run the arduino off an external powersupply (with the USB disconnected) but that did not work either...
WHAT IS WRONG!?
Here is the code:
//from examples *modified
int note = 60;
// Set MIDI baud rate:
//Serial.begin(31250);
pinMode(13,OUTPUT);
//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
noteOn(0x90, note, 0x45);
digitalWrite(13,HIGH);
//Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
noteOn(0x90, note, 0x00);
digitalWrite(13,LOW);
void noteOn(int cmd, int pitch, int velocity) {
Serial.print(cmd, BYTE);
Serial.print(pitch, BYTE);
Serial.print(velocity, BYTE);
/me fail
The baud rate appears to be set to 9600 instead of the proper 31250. Does it work if you comment out the 9600 and enable the 31250?
-br
http://entropymouse.com
How embarrasing!
The 9600 was just for some debugging. I use the 31250 when testing :slight_smile:
And no, it does not work..
http://itp.nyu.edu/physcomp/Labs/MIDIOutput
http://www.arduino.cc/playground/Main/InterfacingWithHardware#MIDI
Ton of info
I don't know anything about midi, so I can't help you here but... I'm guessing english is your second language. :slight_smile:
Using 220ohm (I think the image says 228 [ch937]), read all the info, english is my second language and the post was written as fast as my fingers could type.
:slight_smile:
Normally it is pins 4 & 5 that get swapped, is the diagram you posted looking at the front of the socket or looking at the back?
The ground on pin 2 is not needed and a proper MIDI lead will not have a wire in this position. In fact a ground on pin 2 can cause problems sometimes. Yes I know the ITP web sit has one on but that is one hell of a bad site for errors.
Thank you Grumpy! :slight_smile:
I think the MIDI page should mention that it views the connector from the front (got to blame someone right ;)).
