can you check below cide is correct , my intention is whenver radar sensor output is high first LED will be switched ON , then second time if radar goes high again then second LEd swicthes on , third time when rardar switches to high then 3rd LED switches on and so onn till 4 LEds applied delay for stability , at the same time led1 , 2 & 3 are on one by one till they switch off push switch
full Sketch : compiling & uploading without error but execution not functioninig
int Sensor = 2; // RCWL-0516 Input Pin
int Pbut = 3; // Push button Input Pin
int LED = 13; // LED Output Pin
int LED2 = 4; // LED Output Pin
int LED3 = 5; // LED Output Pin
int LED4 = 12; // LED Output Pin
int sensorval = 0; // RCWL-0516 Sensor Value
int pbval = 0; // Push button value
pinMode (Sensor, INPUT); // RCWL-0516 as input
pinMode (Pbut, INPUT); // Push button as input
pinMode (LED, OUTPUT); // LED as OUTPUT
digitalWrite(LED, LOW); // Turn LED Off
void loop1(void){
delay(2000); // waits for a second
pbval = digitalRead(Pbut); // Read Push button value
if (pbval == HIGH) {
digitalWrite(LED, HIGH); // Turn LED ON
Serial.print(LED);
delay(5000); // waits 5 second
sensorval = digitalRead(Sensor); // Read Sensor value
void loop2(void){
if (sensorval == HIGH && LED == HIGH)
digitalWrite(LED2, HIGH); // Turn LED2 On
Serial.print(LED2);
delay(60000); // waits for 60 second
void loop3(void){
if (sensorval == HIGH && LED == HIGH,LED2==HIGH)
digitalWrite(LED3, HIGH); // Turn LED3 On
void loop4(void){
if (sensorval == HIGH && LED == HIGH,LED2==HIGH,LED3==HIGH )
digitalWrite(LED4, HIGH); // Turn LED4 On
void loop(void) {
loop1();
loop2();
loop3();
loop4();
if (pbval == LOW) {
digitalWrite(LED2, LOW); // Turn LED Off
digitalWrite(LED3, LOW); // Turn LED Off
digitalWrite(LED4, LOW); // Turn LED Off
Serial.print(LED);
