i am trying to build a system in which i can turn on ac devices using an arduino
so i an trying to build an system in which i can turn on ac devices using relay with rfid arduino uno and rc522 rfid reader i have everything working but the relay wont turn on
first code that reads the rfid tags
#include <SPI.h>
#include <MFRC522.h>
#include <EEPROM.h>
#define RST_PIN 9
#define SS_PIN 10
byte readCard[4];
int successRead;
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
SPI.begin();
mfrc522.PCD_Init();
Serial.println("RFID CARD SETUP BY ensarlevent");
Serial.println("--------------------------");
Serial.println("PLEASE SHOW YOUR 1. ID CARD.");
do {
successRead = getID();
while (!successRead);
for ( int i = 0; i < mfrc522.uid.size; i++ )
EEPROM.write(i, readCard );
  • Serial.println("CARD SAVED TO EEPROM");*
  • Serial.println();*
  • Serial.println("PLEASE SHOW YOUR 2. ID CARD.");*
  • do {*
  • successRead = getID();*
  • while (!successRead);*
  • for ( int i = 0; i < mfrc522.uid.size; i++ )*
    _ EEPROM.write(i + 4, readCard );_
    * Serial.println("CARD SAVED TO EEPROM");*
    * Serial.println();*
    * Serial.println("CARDS SAVED PLEASE UPLOAD THE rfid_work CODE");
    _
    Serial.println("IF YOU HAVE A PROBLEM PLEASE CONTACT US.ensarlevent");_
    _
    }_
    _
    {_
    _
    }_
    int getID() {
    if ( ! mfrc522.PICC_IsNewCardPresent()) {
    _
    return 0;_
    _
    }_
    if ( ! mfrc522.PICC_ReadCardSerial()) {
    _
    return 0;_
    _
    }_
    _
    Serial.print("Card ID: ");_
    _
    for (int i = 0; i < mfrc522.uid.size; i++) {_
    readCard _= mfrc522.uid.uidByte;
    Serial.print(readCard, HEX);
    Serial.println("");_
    mfrc522.PICC_HaltA();
    _ return 1;
    second code that exicutes it
    #include <SPI.h>
    #include <EEPROM.h>
    const int buttonPin = 5;
    int buttonState = 0;_
    #define RST_PIN 9*
    #define SS_PIN 10
    String lastRfid = "";
    String card1 = "";
    String card2 = "";
    * pinMode(buttonPin, INPUT);*
    * buttonState = digitalRead(buttonPin);*
* Serial.begin(9600);*
* SPI.begin();*
* mfrc522.PCD_Init();
_ Serial.println("RFID Card Reader");
readEEPROM();
{_
_ {
return;
}_
_ {
return;
String rfid = "";
for (byte i = 0; i < mfrc522.uid.size; i++)
rfid += mfrc522.uid.uidByte < 0x10 ? " 0" : " ";
rfid += String(mfrc522.uid.uidByte, HEX);
rfid.trim();
rfid.toUpperCase();*_
* if (rfid == lastRfid)*
* return;*
* lastRfid = rfid;*
* Serial.print("Card 1: ");*
* Serial.println(card1);*
* Serial.print("Card 2: ");*
* Serial.println(card2);*
* Serial.print("Now: ");*
* Serial.println(rfid);*
* if (rfid == card1)*
* Serial.println("Turned On.");*
* delay (2000);*
* if (rfid == card2)*
* Serial.println("Turned Off");*
* delay (2000);*
* delay(200);*
void readEEPROM()
* for (int i = 0 ; i < 4 ; i++)*
* card1 += EEPROM.read(i) < 0x10 ? " 0" : " ";*
* card1 += String(EEPROM.read(i), HEX);*
* for (int i = 4 ; i < 8 ; i++)*
* card2 += EEPROM.read(i) < 0x10 ? " 0" : " ";*
* card2 += String(EEPROM.read(i), HEX);*
* card1.trim();*
* card1.toUpperCase();*
* card2.trim();*
* card2.toUpperCase();*
please helppppp
Help yourself.
Edit your post and add the code tags.
And.... a circuit diagram.
Why not try a simple program to turn the relay on and off , to help identify what is wrong .
Add print output in your program to track what variables are doing to de bug it
String rfid
Don’t use the String class, use the string class - note the lower case “s”
