I am trying to make an object using a leak sensor and a touch panel
This is a program I made.
action sequence
1)Green light turns on when power is applied
  1. Supply the sol valve by pressing 15 liter in the touch
    (when supplying, the green lamp turns off and the red lamp comes on)
  2. When the liter supply is finished, the green light comes on again.
** 2 types of safety devices -
Water overflow prevention through leak sensor and water level sensor.
Sol valve does not operate even if only one of them is detected.
#include <RTClib.h>
#include <Adafruit_BusIO_Register.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_I2CRegister.h>
#include <Adafruit_SPIDevice.h>
#include <Wire.h>
#include <Arduino.h>
#include <doxygen.h>
#include <NexButton.h>
#include <NexCheckbox.h>
#include <NexConfig.h>
#include <NexCrop.h>
#include <NexDualStateButton.h>
#include <NexGauge.h>
#include <NexGpio.h>
#include <NexHardware.h>
#include <NexHotspot.h>
#include <NexNumber.h>
#include <NexObject.h>
#include <NexPage.h>
#include <NexPicture.h>
#include <NexProgressBar.h>
#include <NexRadio.h>
#include <NexRtc.h>
#include <NexScrolltext.h>
#include <NexSlider.h>
#include <NexText.h>
#include <NexTimer.h>
#include <Nextion.h>
#include <NexTouch.h>
#include <NexUpload.h>
#include <NexVariable.h>
#include <NexWaveform.h>
const int relay = 8;//SOLVALVE
const int led0 = 10;//LAMP GREEN
const int rain = A0;//LEAK SENSOR
const int over = A1;//WATER LEVEL SENSOR
const int led1 = 6;//LAMP RED
NexButton b0 = NexButton(0, 3, "b0");// POWER on switch+
NexButton b11 = NexButton(1, 3, "b11");//POWER OFF
NexButton b21 = NexButton(2, 3, "b21");// 15 L
NexButton b22 = NexButton(2, 4, "b22");// 20 L
NexButton b23 = NexButton(2, 5, "b23");// 30 L
// Register a button object to the touch event list.
NexTouch *nex_listen_list[] = {
  &b21,
  &b0,
  &b11,
 &b22,
  &b23,
  NULL
 void b0PushCallback(void *ptr) {
  digitalWrite(relay, HIGH);
void b11PushCallback(void *ptr) {
  digitalWrite(relay, LOW);
void b21PushCallback(void *ptr) {
  digitalWrite(led0, LOW);
  delay (15000);//15초간 물공급
  digitalWrite(led0, HIGH);
  delay (10);
void b22PushCallback(void *ptr) {
  delay (20000);//20초간 물공급
  delay (10);
void b23PushCallback(void *ptr) {
  delay (25000);//25초간 물공급
  delay (10);
void setup(void) {
  // Set LEDs as outputs
  pinMode(relay, OUTPUT);
  pinMode(led0, OUTPUT);
  pinMode(led1, OUTPUT);
  nexInit();
  b0.attachPush(b0PushCallback, &b0);
  b21.attachPush(b21PushCallback, &b21);
  b22.attachPush(b22PushCallback, &b22);
  b23.attachPush(b23PushCallback, &b23);
  b11.attachPush(b11PushCallback, &b11);
void loop(void){
  {nexLoop(nex_listen_list);}
 Serial.println(analogRead(A0));
  Serial.println(analogRead(A1));
  delay(10);
  if(analogRead(A0)<800||(A1)<800){
    digitalWrite(10,HIGH);
    digitalWrite(8,LOW);
    digitalWrite(6,LOW);
    delay(100);
    digitalWrite(6,HIGH);
    delay(100);
  else{
    digitalWrite(10,LOW);
    digitalWrite(8,HIGH);
```[quote="choifamily, post:1, topic:1056248, full:true"]
action sequence
2) Supply the sol valve by pressing 15 liter in the touch
3) When the liter supply is finished, the green light comes on again.
![2022-11-21 16;46;17|333x500](upload://7vZbhAvGAx0P7S4Qbw2SNCwrZoI.png)
you missed analogRead() of A1
also add some prints so you can see what is going on, e.g.
  if(analogRead(A0)<800||analogRead(A1)<800){
    // is this the close or open of the value?
    Serial.println("close solenoid valve");
what do the values of A0 and A1 mean?
a0- leak sensor
a1 - water level sensor
a0 or a1 = valve off
do high or low values indicate a leak?
which effects the logic of
does high close the solenoid or open it?
comments in code would be helpful
a0- leak sensor = Detect when water overflows.
a1-water level sensor = Detects when the water is above the setting (15 liters).
Both sensors play a role in preventing water from overflowing.
When the sensor is detected, the sol valve power is turned off. The re-solving valve operates again only when there is no water on the sensor.
a0- leak sensor = Detect when water overflows. High or LOW?
a1-water level sensor = Detects when the water is above the setting (15 liters). HIGH or LOW?
