I am using a lora gps sheild with an esp 8266 and blynk please help regurading programming rx node
#define BLYNK_PRINT Serial
#include <SoftwareSerial.h>
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
#include <SPI.h>
#include <LoRa.h>
#include <Ethernet.h>
String longi;
String latt;
float a;
float b;
SoftwareSerial EspSerial(4, 3); // RX, TX
char auth[] = "4RYGKOFS-V7ihYHwuGl6F4EjirgzVgI-";
WidgetMap myMap(V0);
BlynkTimer timer;
char ssid[] = "redmi";
char pass[] = "";
unsigned int move_index = 1;
#define ESP8266_BAUD 115200
ESP8266 wifi(&ESPSerial);
while (!Serial);
EspSerial.begin(ESP8266_BAUD);
Serial.println("LoRa Receiver");
if (!LoRa.begin(868E6)) {
Serial.println("Starting LoRa failed!");
while (1);
Blynk.begin(auth, wifi, ssid, pass);
Blynk.run();
myMap.location(move_index, a, b, "GPS_Location");
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
   longi = LoRa.readStringUntil(':');
   Serial.print(longi);
   a=longi.toFloat();
    Serial.print(" ");
   latt = LoRa.readStringUntil(':');
    Serial.print(latt);
    b=latt.toFloat();
    // print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
timer.run();
this ia the code iam using its not working please help
how have you connected the shield to the ESP8266?
what appears on the Serial Monitor?
use code tags around your code - it is very difficult to read as it is
