I am using milliss () function as shown in the code. But noted that the message comes after the period = 30000... But I want to first display the messsage and then display again after period using millis function.. Can someone help me get this done?
int period = 30000;
unsigned long time_now = 0;
Serial.begin (9600);
if(millis() > time_now + period){
time_now = millis();
Serial.print ("You got messagae");
Perhaps that?
@Idahowalker Thi is still working after the period.. The message is coming after the period...I want the message to come and then come again after period....
Is there a way do..while loop can help?
Add a copy of the print statement to the end of setup.
@Whandall Kindly show me in the code
There is only one print statement, only one setup, only one end of that routine.
Now you'll get a message after 3 seconds or every loop.
Oh you want the message to print all the time OK.
Show me what you mean by editing my code please
This will make the message A continuously.... I want the message to work once and then other after millis.
That's why I was asking if do...while loop will work
int period = 30000;
bool DisplayFirstTime = true;
if((millis() - time_now >= period) || DisplayFirstTime ){
DisplayFirstTime = false;
What does that mean?
Wow... This works well . Thank you so much
This works well... can you explain the code please?
In case I want to implement it elsewhere?
Perhaps you might understand a simpler version:
int period = 30000;
unsigned long time_now = millis() - period;
  if((millis() - time_now >= period) {
int period = 30000;
  // The || means 'or', so it reads like : if the period has passed or DisplayFirstTime is true
  // it then sets DisplayFirstTime to false, this allows only the timer to work.
  if ((millis() - time_now >= period) || DisplayFirstTime )
Can this work with a function....If I replace the Serial.print ("You got messagae") with a function...Let's say a function call to send SMS
With or without the 30 second delay?
Without:
void oneTime() {
  static bool firstTime = true;
  if (firstTime) {
  firstTime = false;
Yes. Just add "time_now == 0 || " to the beginning of the timer check. This will cause the 'if' to display the message the first time through loop() and then again every 30 seconds.
const unsigned int period = 30000;
  if (time_now == 0 || millis() - time_now >= period)
As you can see, there are multiple solutions to implementing this task...
It will probably fill the serial buffer until it blocks, before the first millisecond is over.
