I am working on some personal project which requires the help of firebase to send data to node MCU with the help of wifi but , error while compiling
#include <Arduino.h>
#if defined(ESP32)
  #include <WiFi.h>
#elif defined(ESP8266)
  #include <ESP8266WiFi.h>
#endif
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
#include <DFRobot_DHT11.h>
DFRobot_DHT11 DHT;
#define DHT11_PIN 10
// Insert your network credentials
#define WIFI_SSID "PRINCE" //OnePlus Nord CE 2
#define WIFI_PASSWORD "saibaba@12" //qpqpwowo
// Insert Firebase project API Key
#define API_KEY "AIzaSyCvJki3BGbZLjytyG8Qpcn4PUkLKOIlh8s"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "https://tryproject-2f59e-default-rtdb.firebaseio.com/"
#define Switch 8
#define Motor 5
#define Pump 6
//Define Firebase Data object
FirebaseData fbdo1;
FirebaseData fbdo2;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
int count = 0;
int fanValue;
int pumpValue;
int switchValue;
bool signupOK = false;
int humi, temp;
void setup(){
  pinMode(Motor,OUTPUT);
  pinMode(Pump,OUTPUT);
  pinMode(Switch, INPUT);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
  while (WiFi.status() != WL_CONNECTED){
    Serial.print(".");
    delay(300);
  Serial.print("Connected with IP: ");
  Serial.print(WiFi.localIP());
  config.api_key = API_KEY;
  config.database_url = DATABASE_URL;
  /* Sign up */
  if (Firebase.signUp(&config, &auth, "", "")){
    Serial.println("ok");
    signupOK = true;
  else{
    Serial.printf("%s\n", config.signer.signupError.message.c_str());
  /* Assign the callback function for the long running token generation task */
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
void runCooler(){
  if ((humi>=70 && temp >= 32) || (humi<=70 && humi >= 60 && temp <= 32 && temp >= 28 ) || (humi<=70 && humi >= 60 && temp >= 32 ) || (humi<=60 && temp <= 32 && temp >= 28 ) ){
    digitalWrite(Motor, LOW);
    digitalWrite(Pump,LOW);
  else if ((temp <= 28 && humi <= 60) || (temp <= 28 && ( humi>60 || humi <= 70))){
      digitalWrite(Motor,HIGH);
      digitalWrite(Pump,HIGH);
  else if ((temp<=28 && humi>=70)|| (temp<=32 & temp>=28 && humi>70)){
      digitalWrite(Motor,LOW);
void loop(){
  switchValue = digitalRead(Switch);
  int appSwitch;
  if (Firebase.RTDB.getInt(&fbdo1, "/Component/Switch/")) {
    if (fbdo1.dataType() == "int") {
      appSwitch = fbdo1.intData();
      Serial.println(appSwitch);
      if (appSwitch == 1){
        runCooler();
      else {
  else if ( switchValue = 1){
    runCooler();
  else{
I faced the error such as No Primary expression before '.', on the code line
could you upload all the error messages displayed?
Wifi.localIP() can't be printed directly, you have to convert it to String or char array first
PS It's not a good idea to give a topic two lines long title, especially since this title does not express the essence of the issue.
WiFi connected
Server started
192.168.1.167
