I become creasy on a ")" error
Dear All,
I look on a existing library and I am trying to do the same.
Then my code is similar but when I compile, I can see that error:
In file included from /Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp:2:
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.h:17: error: expected )' before '*' token /Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp:4: error: expected )’ before ‘*’ token
I become “creasy” because I lool and looked when a ) is missing and I could not find and undertsand the error.
May I ask to help me?
Here is the code
Sim908_v6.ino
#include <SoftwareSerial.h>
#include <Sim908.h>
// GENERAK
#define DEBUG
int pinToPowerOnModule = 8;
// LED
int green = 12;
#define MSEC 500
#define MSEC_FAST 150
// SERIAL
int baud_rate = 9600;
#define RXPIN 2
#define TXPIN 3
Sim908 sim908(new SoftwareSerial(RXPIN, TXPIN), baud_rate, pinToPowerOnModule);
  pinMode(green, OUTPUT);
  //sim908.blinkLed(green, 1, MSEC);
Here is my Sim908.h file
  Sim908.h - Library
#ifndef Sim908_h
#define Sim908_h
#include "Arduino.h"
class Sim908{
	private:
		int _pinToPowerOnModule;
		//SoftwareSerial _cell;
		Stream* _cell;
	public:
		Sim908(SoftwareSerial* serial, int baud_rate, int pinToPowerOnModule);
		void blinkLed(int lPin, int nBlink, int msec);
#endif
and here is the last file, Sim908.cpp (I only copy the code which make problem
#include "Sim908.h"
Sim908::Sim908(SoftwareSerial* serial, int baud_rate, int pinToPowerOnModule)
	pinMode(pinToPowerOnModule, OUTPUT);
	_pinToPowerOnModule = pinToPowerOnModule;
	_cell = serial;
Where is the problem with a ) ???
Many thank for your help!!
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.h:17: error: expected `)' before '*' token
So, what does line 17 of Sim908.h look like?
OK, so where is there a * token? Can you spot it?
The compiler is telling you that there is something wrong with that line. It doesn't recognize SoftwareSerial as anything, so it thinks that perhaps you've forgotten a ) before it.
Of course, adding a parentheses before the * is not the correct solution.
I'm hoping that you recognize what the correct solution is, given this explanation.
This line look strange
...R
Why? That is no different from:
SoftwareSerial *pSS = new SoftwareSerial(RXPIN, TXPIN);
Sim908 sim908(pSS, baud_rate, pinToPowerOnModule);
PaulS:
Ahhh.
I only do simple stuff ...
...R
Dear PaulS
Thank for your help.
In fact I compared my file my exemple file. I missed to add
in the Sim908.h file.
Since the error message desapeared and I do have other error.
Was what you thouth about?
Cheers
Feel free to post them, and the modified code.
Oups sorry, I wanted to write
I do not have other error. :slight_smile: :slight_smile:
Thank to you
