I.C. Help
Could anyone tell me if there is an I.C. that acts as two latching relays (power isn't important) with both "relays" having set & unset pins?
Many thanks,
Mick.
Do a search for flip-flops, more specifically RS flip-flops, I think that will suit your needs and also explain how they work.
With regards Mike
You may look into 74LS74; it contains 2 D-type flip-flops with individual SET/ and CLR/ pins.
A type D flip flop is not what the OP asked about, RS behavior is what was described. A simple RS f/f can be constructed with two nand or nor gates.
A type D will change its output high only when the input is high and clock pulse pulse occurs. This is totally different behavior than a simple set-reset flip flop which is an analog of a mechanical latching relay, without state retention.
avr_fred:
A 74LS74 has a set and clear.
Thank you,
Looking on the RS Components website they don't seem to have a "Logic Family" for RS type, could they be calling it something else?
EDIT: I think I've found them, they call them SR,
Could someone please advise if these are suitable:
Thank you.
Sure.
Or
You can use simple and cheap NAND or NOR gates.
Thanks.
Wiring images of the SR flip-flops using discrete logic gates:
