If you read my post #8 thoroughly you will see that just deleting the line inside the while() loop does not help to overcome synchronization issues.
Synchronization means: Always read complete messages terminated by '\n'
I tried to implement the second snippet from my postg #8 to your code from post #11; not tested but feel free to give it a try:
#include <Wire.h>
#include "RTClib.h"
#include <Keypad.h>
#include <KnxTpUart.h>
#include <stdio.h>
#include <stdlib.h>
#include "DHT.h"
#if defined(ARDUINO) && ARDUINO >= 100
#define printByte(args) write(args);
#else
#define printByte(args) print(args, BYTE);
#endif
int estado_luz_salon = 0;
int estado_luz_dormitorio = 0;
//Variables KNX
KnxTpUart knx(&Serial1, "1.1.30");
//Variables RTC
uint8_t clock[8] = { 0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0 };
RTC_DS3231 RTC;
//Variables LCD
LiquidCrystal_I2C lcd(0x27, 16, 2);
String diasSemana[7] = { "DOM", "LUN", "MART", "MIER", "JUEV", "VIER",
"SAB" };
//Variables Teclado Matricial
const byte filas = 4;
const byte columnas = 4;
const byte pinesColumnas[filas] = { 5, 4, 3, 2 };
const byte pinesFilas[columnas] = { 9, 8, 7, 6 };
char formatoTeclado[filas][columnas] = {
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ '*', '0', '#', 'D' }
Keypad teclado = Keypad(makeKeymap(formatoTeclado),
(byte*)pinesFilas, (byte*)pinesColumnas, filas, columnas);
//Variables Zumbador
const int zumbador = 10;
//Variables PIR
#define pinSensor 11
//Variables DHT11
const int pinDTH = 12;
DHT dht(pinDTH, DHT11);
//Variables globales
int movimiento = 0;
int intentos = 0;
int repeticionesPantalla = 0;
bool alarmaSalirActivada = false;
bool alarmaDespertarActivada = false;
String tempString = "";
String respuesta = "";
Serial.begin(19200); // Inicia Serial
pinMode(zumbador, OUTPUT); //Establece el pin 10 de salida al que
Wire.begin(); //Inicializa la biblioteca Wire para permitir la
//Inicializacion del RTC
if (!RTC.begin()) {
while (1)
// Si se ha perdido la corriente, fijar fecha y hora de compilacion
if (RTC.lostPower()) {
RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
// Inicializa la pantalla LCD y luz de fondo
lcd.init();
lcd.backlight();
//Inicia el sensor DHT
dht.begin();
//Inicia KNX
Serial1.begin(19200, SERIAL_8E1);
Serial2.begin(19200);
knx.uartReset();
//Escena Me voy
knx.addListenGroupAddress("0/1/1");
//Escena Dormir
knx.addListenGroupAddress("0/1/2");
Serial.println("Added listen group adress ");
knx.groupRead("0/1/1");
knx.groupRead("0/1/2");
Serial.println("Read group address ");
//Se recorre de manera repetitiva y a la velocidad del procesador
if (repeticionesPantalla != 5) {
pantallaLCD();
pantallaTempHumedad();
//Código para la puesta de la alarma despertar
while (alarmaDespertarActivada) {
if (preguntarEstablecerDespertador()) {
String hora = insertarHoraDespertar();
esperarDespertador(hora);
//Código para la puesta de la alarma al irnos de casa
while (alarmaSalirActivada) {
activarBuzzerPonerAlarma();
while (movimiento == LOW) {
pantallaLCD();
lecturaPIR();
LCDMovimientoDetectado();
movimiento = LOW;
respuesta = "";
while (Serial2.available() > 0) {
char receivedChar = Serial2.read();
if (receivedChar == '\n') {
respuesta = tempString;
tempString = "";
Serial.println(respuesta);
delay(1000); // Print the received message in the Serial monitor
tempString += receivedChar; // Append characters to the received message
if (respuesta == "/sube_persiana") {
//persiana
knx.groupWriteBool("2/0/0", 0);
if (respuesta == "/baja_persiana") {
//persiana
knx.groupWriteBool("2/0/0", 1);
if (respuesta == "/enciende_luz_dormitorio") {
//dormitorio
Serial.println("Here");
bool xd = true;
knx.groupWriteBool("1/0/1", xd);
if (respuesta == "/apaga_luz_dormitorio") {
//dormitorio
knx.groupWriteBool("1/0/1", 0);
if (respuesta == "/enciende_luz_salon") {
//salon
knx.groupWriteBool("1/0/0", 1);
if (respuesta == "/apaga_luz_salon") {
//salon
knx.groupWriteBool("1/0/0", 0);
void serialEvent1() {
KnxTpUartSerialEventType tipoEvento = knx.serialEvent();
Serial.println("knx.serialEvent()");
if (tipoEvento == KNX_TELEGRAM) {
KnxTelegram* telegram = knx.getReceivedTelegram();
KnxCommandType tipoComando = telegram->getCommand();
if (tipoComando == KNX_COMMAND_WRITE) {
Serial.println("Received KNX_COMMAND_WRITE");
String grupoOrigen =
String(0 + telegram->getTargetMainGroup()) + "/" + String(0 + telegram->getTargetMiddleGroup()) + "/" + String(0 + telegram->getTargetSubGroup());
Serial.println("GrupoOrigen :" + grupoOrigen);
if (grupoOrigen == "0/1/1") {
Serial.println("Activada escena Me voy");
alarmaSalirActivada = true;
} else if (grupoOrigen == "0/1/2") {
Serial.println("Activada escena Dormir");
alarmaDespertarActivada = true;
//Mostrar fecha y hora en LCD
void pantallaLCD() {
lcd.clear();
DateTime valorRTC = RTC.now();
//FECHA
lcd.setCursor(0, 0);
lcd.print("");
lcd.print(diasSemana[valorRTC.dayOfTheWeek()]);
lcd.print(" ");
lcd.print(valorRTC.day(), DEC);
lcd.print('/');
lcd.print(valorRTC.month(), DEC);
lcd.print('/');
lcd.print(valorRTC.year(), DEC);
//HORA
lcd.setCursor(0, 1);
lcd.print("HORA: ");
lcd.print(valorRTC.hour(), DEC);
lcd.print(':');
lcd.print(valorRTC.minute(), DEC);
lcd.print(':');
lcd.print(valorRTC.second(), DEC);
repeticionesPantalla++;
void pantallaTempHumedad() {
float humed = dht.readHumidity();
float temper = dht.readTemperature();
if (isnan(humed) || isnan(temper)) {
Serial.println("Fallo en la lectura del sensor DHT11");
lcd.clear();
//TEMPERATURA
lcd.print("TIEMPO: ");
lcd.print(temper);
lcd.print((char)223);
lcd.print("C");
//HUMEDAD
//TEMPERATURA
lcd.print("HUMEDAD: ");
lcd.print(humed);
lcd.print(" %");
delay(3000);
//Lectura del sensor PIR
int lecturaPIR() {
movimiento = digitalRead(pinSensor);
return movimiento;
bool preguntarEstablecerDespertador() {
char establecerAlarma;
bool establecerBool = false;
int establecer = 0;
lcd.clear();
lcd.print("PONER ALARMA?");
lcd.print("A=SI B=NO");
while (establecer != 1) {
establecerAlarma = teclado.getKey();
if (establecerAlarma == 'A') {
lcd.clear();
lcd.print("ACTIVAR ALARMA");
delay(3000);
lcd.clear();
establecerBool = true;
establecer++;
} else if (establecerAlarma == 'B') {
lcd.clear();
lcd.print("ALARMA");
lcd.print("NO ACTIVADA");
delay(3000);
lcd.clear();
establecer++;
return establecerBool;
String insertarHoraDespertar() {
int i;
lcd.print("INTRODUZCA HORA");
String horaCompleta = "";
char horaAlarma;
char correcto;
String caracterPuntos = ":";
for (i = 0; i <= 4; i++) {
if (i == 2) {
lcd.setCursor(i, 1);
lcd.print(caracterPuntos);
horaCompleta = horaCompleta + caracterPuntos;
horaAlarma = teclado.waitForKey();
lcd.print(horaAlarma);
horaCompleta = horaCompleta + String(horaAlarma);
validarHoraDespertar(horaCompleta);
lcd.clear();
return horaCompleta;
void validarHoraDespertar(String horaInsertada) {
char horaAlarma;
bool hora = getValidarHora(horaInsertada, 0);
bool minutos = getValidarHora(horaInsertada, 1);
Serial.println(String(hora));
Serial.println(String(minutos));
if (hora && minutos) {
delay(2000);
lcd.clear();
lcd.print("CORRECTO?" + horaInsertada);
lcd.print("A=SI B=NO C=EX");
if (horaAlarma == 'A') {
lcd.clear();
lcd.print("ESTABLECIDA");
delay(3000);
lcd.clear();
} else if (horaAlarma == 'B') {
lcd.clear();
} else if (horaAlarma == 'C') {
lcd.clear();
lcd.print("HORA INVALIDA");
delay(2000);
lcd.clear();
void esperarDespertador(String hora) {
int horas = getValue(hora, ':', 0).toInt();
int minutos = getValue(hora, ':', 1).toInt();
do {
pantallaLCD();
} while (valorRTC.hour() != horas || valorRTC.minute() != minutos);
activarBuzzerDespertador();
activarEscenaDespertar();
void activarEscenaDespertar() {
Serial.println("Activada escena Despertar");
Serial.println("Subo persiana");
knx.groupWrite4BitInt("2/0/0", 0);
Serial.println("Subo enciendo luz dormitorio");
knx.groupWriteBool("1/0/1", true);
//Indica si se ha detectado movimiento
void LCDMovimientoDetectado() {
lcd.clear();
lcd.print("INSERTE CODIGO");
lcd.print("DESBLOQUEO");
delay(3000);
indicarCorrectoCodigoDesbloqueo();
//Indica al lcd si el código introducido es correcto
void indicarCorrectoCodigoDesbloqueo() {
bool correcta = false;
intentos = 0;
while ((intentos != 3) && (correcta == false)) {
correcta = pedirCodigoDesbloqueo();
//Contraseña introducida es correcta
if (correcta == true) {
lcd.clear();
lcd.println("***BIENVENIDO***");
lcd.println("*****A CASA*****");
delay(3000);
intentos = 0;
//Contraseña incorrecta.
//Hasta 3 imprime mensaje de que continue.
//En 3 suena buzzer
else {
lcd.clear();
//Muchas veces equivocando
if (intentos == 3) {
lcd.print("****DETECTADO***");
lcd.print("*****LADRON*****");
delay(2000);
activarBuzzerLadron();
lcd.print("CODIGO ERRONEO");
lcd.print("VUELVE A PROBAR");
delay(2000);
//Pide al usuario el código de 4 dígitos de desbloqueo
bool pedirCodigoDesbloqueo() {
int posicion = 1;
lcd.clear();
char digitoPass;
int digitoCorrecto = 0;
bool passCorrecta = false;
//Pedir los 4 dígitos de la contraseña
while (posicion != 5) {
char caracter = teclado.getKey();
if (caracter) {
if (posicion == 1) {
digitoPass = 'A';
lcd.clear();
lcd.print("*");
digitoCorrecto += comprobarCodigoDesbloqueo(digitoPass,
caracter);
posicion++;
} else if (posicion == 2) {
digitoPass = '3';
lcd.clear();
lcd.print("**");
digitoCorrecto += comprobarCodigoDesbloqueo(digitoPass, caracter);
posicion++;
} else if (posicion == 3) {
digitoPass = '2';
lcd.clear();
lcd.print("***");
posicion++;
digitoPass = '1';
lcd.clear();
lcd.print("****");
posicion++;
intentos++;
if (digitoCorrecto == 4) {
passCorrecta = true;
return passCorrecta;
//Comprueba si el dígito establecido en la contraseña es igual al
int comprobarCodigoDesbloqueo(char caracterEstablecido, char caracterIntroducido) {
//Compruebo si la contraseña es igual a la establecida
if (caracterEstablecido == caracterIntroducido) {
digitoCorrecto = 1;
digitoCorrecto = 0;
return digitoCorrecto;
void activarBuzzerLadron() {
int contador = 0;
while (contador != 2) {
tone(zumbador, 50); // Envía señal de 1Khz al zumbador
noTone(zumbador); // Detiene el zumbador
delay(1000); //Espera un segundo y vuelve a repetir el bucle
contador++;
void activarBuzzerPonerAlarma() {
int contador = 0;
while (contador < 3) {
tonoInicio();
contador++;
contador = 0;
while (contador < 2) {
tonoMedio();
contador++;
contador = 0;
while (contador < 4) {
tonoFinal();
contador++;
void tonoInicio() {
tone(zumbador, 440);
delay(1500); //Espera un segundo y vuelve a repetir el bucle
void tonoMedio() {
delay(750); //Espera un segundo y vuelve a repetir el bucle
void tonoFinal() {
delay(250);
delay(250); //Espera un segundo y vuelve a repetir el bucle
void activarBuzzerDespertador() {
int contador = 0;
while (contador != 1) {
contador++;
contador = 0;
bool getValidarHora(String datos, int index) {
String hora = getValue(datos, ':', index);
int datosLong = datos.length();
char datosChar[datosLong + 1];
bool valido = true;
hora.toCharArray(datosChar, datosLong);
for (int i = 0; i < datosLong; i++) {
switch (datosChar[i]) {
case 'A':
return false;
break;
case 'B':
return false;
break;
case 'C':
return false;
break;
case 'D':
return false;
break;
case '#':
return false;
break;
case '*':
return false;
break;
int horaInt = hora.toInt();
if (index == 0 && ((horaInt >= 0 && horaInt <= 23))) {
return true;
} else if (index == 1 && ((horaInt >= 0 && horaInt <= 59))) {
return true;
String getValue(String data, char separator, int index) {
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i + 1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
Good luck!
