I can flash my board only once, fuses trouble?
Hi everyone,
I make a custom board for a project with an ATmega328p-an. I have a mac computer, and I try to put a bootloader in it.
To flash it I have an AVRISP mkII and an AVRDRAGON.
Arduino IDE tests
At the beginning I simply try to use the arduino IDE to write it with the dragon, but I can't find any AVRDRAGON on the IDE arduino. So I just switch to the MKII and I got some signature troubles.
Expected signature for ATmega328P is 1E 95 14
To patch it I just change the signature value on the /Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf under "328p" configuration I change 1E 95 14 to 1E 95 0F.
After that i have another issue due to the MKII because this thing is not supported anymore :
avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xff instead of 0x3f (double check with your datasheet first).
Command line tests
After this fail I choose to try it using old school (but effective) command line.
With this method I succeed to write the bootloader and fuses into the 328p-an, but I can flash it using the Arduino IDE only once.
My instinct tells me "this is a fuse issue, you dont enable the bootloader one..."
But after a lot of test a can't achieve to flash a code with the arduino IDE multiple time.
I do it in 3 steps, unlock the memory and write fuses :
avrdude -p m328p -b 115200 -v -P usb -u -c avrispmkII -e -U lock:w:0x3f:m -U lfuse:w:0xff:m -U hfuse:w:0xde:m -U efuse:w:0x05:m
avrdude: Version 6.3, compiled on Sep 17 2016 at 02:19:28
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/6.3/etc/avrdude.conf"
         User configuration file is "/Users/nico/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : avrispmkII
         Overriding Baud Rate          : 115200
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200097996
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version Master : 1.12
         Vtarget         : 5.1 V
         SCK period      : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xff != 0x3f
avrdude: verification error; content mismatch
avrdude done.  Thank you.
Write the bootloader :
avrdude -p m328p -b 115200 -P usb -c avrispmkII -D -u -v -U flash:w:/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i
avrdude: reading input file "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
avrdude: writing flash (32670 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32670 bytes of flash written
avrdude: verifying flash memory against /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: load data flash data from input file /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: input file /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
avrdude: reading on-chip flash data:
avrdude: 32670 bytes of flash verified
And lock the memory at the end:
avrdude -p m328p -b 115200 -P usb -v -u -c avrispmkII -U lock:w:0x0f:m
avrdude: reading input file "0x0f"
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
         0xcf != 0x0f
After that I can use the bootloader only one time.
What's wrong with it?
