Using board '328' from platform in folder: C:\Users\JAKIR RAHIMA\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\JAKIR RAHIMA\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3
Detecting libraries used...
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\sketch\\ir-code-new.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\sketch\\ir-code-new.ino.cpp" -o "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\sketch\\ir-code-new.ino.cpp" -o "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\sketch\\ir-code-new.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\JAKIR RAHIMA\AppData\Local\Temp\arduino-core-cache\core_53bbd31d8b191fb7d7c170f20a211315.a
Linking everything together...
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.elf" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756\\sketch\\ir-code-new.ino.cpp.o" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/..\\arduino-core-cache\\core_53bbd31d8b191fb7d7c170f20a211315.a" "-LC:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756" -lm
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.elf" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.eep"
"C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.elf" "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.hex"
cmd /C "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino.elf" > "C:\\Users\\JAKIR RAHIMA\\AppData\\Local\\Temp\\arduino-sketch-0FFA7BBA0308616FA837CECD39CD4756/ir-code-new.ino_atmega328p_16000000L.lst"
'C:\Users\JAKIR' is not recognized as an internal or external command,
operable program or batch file.
exit status 1
Compilation error: exit status 1
Help us help you...
What code?
just blink code
What core are you using?
It looks like "minicore" may have problems with spaces in the path name.
EDIT
Indeed: Compile fails when there is a space in the folder name · Issue #239 · MCUdude/MiniCore · GitHub
update to the latest version of minicore.
