I can not find how to fix my code
int ledPins[] = {2,3,4,5,6,7,8,9};
pinMode(ledPins[0],OUTPUT);
pinMode(ledPins[1],OUTPUT);
pinMode(ledPins[2],OUTPUT);
pinMode(ledPins[3],OUTPUT);
pinMode(ledPins[4],OUTPUT);
pinMode(ledPins[5],OUTPUT);
pinMode(ledPins[6],OUTPUT);
pinMode(ledPins[7],OUTPUT);
void oneAfterAnotherLoop(){
int delayTime = 100; }
for(int i = 0; i <= 7; i++){
digitalWrite(ledPins[i], HIGH);
delay(delayTime);
Please edit your post, select all code and click the </> button to apply code tags. Next save your post.
Code tags make it easier to read, easier to copy and prevent the forum software from mangling your code; e.g. [] does not change to [].
Please describe the problem. Does it not compile? Does it not do what you want it to do in which case the question is what you want it to do :slight_smile:
The code is incomplete. Post the whole code. Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
If there are errors, please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Ah, this is outside a function by the looks of it. And you're missing the loop() function.
