I can not find my problem
'''// Include Libraries
#include <esp_now.h>
#include <WiFi.h>
#include <Adafruit_SSD1306.h>
#include <Wire.h>
Adafruit_SSD1306 display(128, 64, &Wire, -1);
const int analogValue = analogRead(34);
// Define variables to store incoming readings
int analogvalue = 0
//Define a data structure
typedef struct struct_message {
char a[32];
int b "send analogValue to myDate"
} struct_message;
// Create a structured object
struct_message myData;
// Callback function executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Data received: ");
Serial.println(len);
Serial.print("Character Value: ");
Serial.println(myData.a);
Serial.print("analogValue: ");
Serial.println(myData.b);
//set the resolution to 12 bits (0-4096)
analogReadResolution(8);
// Set up Serial Monitor
if (!display.begin(SSD1306 , 0x3C))
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.clearDisplay();
// Set ESP32 as a Wi-Fi Station
WiFi.mode(WIFI_STA);
NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Register callback function
esp_now_register_recv_cb(OnDataRecv);
// read the analog / millivolts value for pin 34:
int analogVolts = analogReadMilliVolts(34);
display.setTextColor(WHITE); display.clearDisplay();
display.setTextSize(2); display.setCursor(20,0); display.print("B3 Design");
display.setCursor(10,18); display.print("AnalogValue");
display.setTextSize(3); display.setCursor(25,42); display.print(myData.a,myData.b);
display.display();
You really have a problem.
Read the two links below!
  1. BEGINNERS and LEARNERS read this... - Using Arduino / Project Guidance - Arduino Forum
  2. How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
Please try harder when creating your post.
There is a sticky post in each forum category that explains how to get the best when asking a question…
“I cannot find my problem” won’t do it.
Code tags, context, error messages, and an explanation of your problem - is a good place to start.
A hardware problem needs a schematic (not a Fritzing picture).
Please edit your post to add code tags, and describe the problem.
I found your problem.
Your problem is not following the rules.
I see A problem immediately and without my typical snark. (Only because I am late to the party).
Hint: CTRL T.
Read the introductory threads mentioned about others.
