I can not get Bluetooth to work
I am modifying the Elegoo smart car V3 and i can not get the Bluetooth to work. I can not find or fix the problem in my code. The Bluetooth can not connect to a device. If someone can help it would be appreciated.
//www.elegoo.com
#include <Servo.h>  //servo
Servo myservo;      //servo
int pos = 90;
#define ENA  5
#define ENB  6
#define IN1  7
#define IN2  8
#define IN3  9
#define IN4  11
#define LED1  13
unsigned char carSpeed = 250;
bool state = LOW;
char getstr;
void forward(){
myservo.write(pos);
  digitalWrite(ENA,HIGH);
  digitalWrite(ENB,HIGH);
  digitalWrite(IN1,HIGH);
  digitalWrite(IN2,LOW);
  digitalWrite(IN3,LOW);
  digitalWrite(IN4,HIGH);
  Serial.println("Forward");
   digitalWrite(ENA,LOW);
   digitalWrite(ENB,LOW);
void back(){
  myservo.write(pos);
  digitalWrite(IN1,LOW);
  digitalWrite(IN2,HIGH);
  digitalWrite(IN3,HIGH);
  digitalWrite(IN4,LOW);
  Serial.println("Back");
void left(){
  myservo.write(pos);
  analogWrite(ENA,carSpeed);
  analogWrite(ENB,carSpeed);
  Serial.println("Left");
void right(){
  myservo.write(pos);
  Serial.println("Right");
void RightForwardSlow(){
   for (pos = 90; pos <= 135; pos += 1)
  Serial.println("RightForwardSlow");
  myservo.write(pos);
    void RightForwardFast(){
   for (pos = 90; pos <= 160; pos += 1)
  digitalWrite(IN2,LOW); //RightForwardFast
  Serial.println("RightForwardFast");
  myservo.write(pos);
void LeftForwardSlow(){
   for (pos = 90; pos <= 45; pos += 1)
  Serial.println("LeftForwardSlow");
  myservo.write(pos);
void LeftForwardFast(){
   for (pos = 90; pos <= 20; pos += 1)
  Serial.println("LeftForwardFast");
  myservo.write(pos);
void stop(){
  myservo.write(pos);
  Serial.println("Stop!");
void BackSlowRight(){
  Serial.println("BackSlowRight");
    myservo.write(pos);
void BackFastRight(){
  Serial.println("BackFastRight");
    myservo.write(pos);
   void BackFastLeft(){
  Serial.println("BackFastLeft");
    myservo.write(pos);
     void BackSlowLeft(){
  Serial.println("BackSlowLeft");
    myservo.write(pos);
void stateChange(){
  state = !state;
  digitalWrite(LED1, state);
  Serial.println("Light");
       void DontGo(){
        myservo.write(pos);
   Serial.println("stop");
  myservo.attach(9);
  pinMode(LED1, OUTPUT); //this down to stop is motor
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
  pinMode(ENA,OUTPUT);
  pinMode(ENB,OUTPUT);
  stop();
  getstr = Serial.read();
  Serial.print(getstr);
  switch(getstr)
    case 'f': forward(); return;
    switch(getstr)
    case 'm': back();   return;
    switch(getstr)
    case 'l': left();   return;
    switch(getstr)
    case 'r': right();  return;
    switch(getstr)
    case 'n': RightForwardSlow(); return;
    switch(getstr)
    case 'o': RightForwardFast(); return;
    switch(getstr)
    case 'd': LeftForwardSlow(); return;
    switch(getstr)
    case 'h': LeftForwardFast(); return;
    switch(getstr)
    case 'k': BackSlowRight(); return;
    switch(getstr)
    case 'g': BackFastRight(); return;
    switch(getstr)
    case 'u': BackFastLeft(); return;
    switch(getstr)
    case 'w': BackSlowLeft(); return;
    switch(getstr)
    case 'a': stateChange(); return;
    switch(getstr)
    case 's': DontGo(); return;
    switch(getstr)
    default:  return;
Which Bluetooth device are you using and which Arduino pins is it connected to ?
Not 0 and 1 by any chance ?
Where is your bluetooth connected to the Arduino ? what Bluetooth device do you have ? How are you trying to make it connect to a device ? How about first using an example sketch for the bluetooth without all the servo control ?
What Arduino board are you using? What Bluetooth module? Can you post a wiring diagram? To what device are you attempting to connect? Will the Bluetooth module pair with the mystery device?
