I can not send GET from Arduino ethernet
Dear,
I have a web server inside an arduino Mega and the ethernet module. But I also need from it to send a GET request.
I'm not able to, answer "Connection Failed". Could you please tell me where the error is?
The IPs are local. The web server works perfect.
Tkx, Nahuel
#include <SPI.h>
#include <Ethernet.h>
#include <EEPROM.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(10, 240, 16, 23);
//IPAddress ip(192, 168, 1, 110);
EthernetServer server(8080);
EthernetClient clientPutin;
//Variables
int CNTRL_Modulos = EEPROM.read(1);
String Sensor;
byte server2[] = { 10, 240, 11, 138 };
while (!Serial) {
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
if (clientPutin.connect(server2, 80)) {
Serial.println("connected");
clientPutin.println("GET /?prueba=30 HTTP/1.1");
clientPutin.println(F("Connection: close"));
clientPutin.println();
clientPutin.stop();
Serial.println("connection failed");
//for (int x = 0; x < 4096; x++) {
// delay(1);
// EEPROM.write(x, 0);
if (client) {
while (client.connected()) {
if (client.available()) {
String text = client.readString();
Is your Gateway Router and your DNS Server at 10.240.16.1? If not, you won't be able to get to the router. If you specify an IP address of A.B.C.D and don't specify an address for your Gateway Router or DNS Server the library assumes they are at A.B.C.1.
Yes. The code you posted incorrectly is incomplete. The snippet you posted does NOT make a GET request.
