I can not stop to Adafruit ImageReader
Hi, I started using the Adafruit ImageReader with a 1.4" TFT display and an ESP32.
My project includes also an keyboard and I'm trying to have the images sliding until any key got pressed in order to execute the rest of the code allowing other functions to use the TFT display..
But it does not happen, the images keep appearing. I tried whit If() and while() statements but once the presentation starts no other functions can use the display.
I really appreciate your advice. Thanks.
I attach a brief code with this behavior.
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <i2ckeypad.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <Adafruit_ImageReader.h> // Image-reading functions
#include <RTClib.h>               // incluye libreria para el manejo del modulo RTC
#define ROWS 4
#define COLS 3
#define PCF8574_ADDR 0x20
i2ckeypad Teclado = i2ckeypad(PCF8574_ADDR, ROWS, COLS);
#define SD_CS    16 // SD card select pin
#define TFT_CS     26
#define TFT_RST    -1
#define TFT_DC     5
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
Adafruit_ImageReader reader;     // Class w/image-reading functions
Adafruit_Image       img;        // An image loaded into RAM
int32_t              width  = 0, // BMP image dimensions
                     height = 0;
char Text[16];
int Ind = 0;
  ImageReturnCode stat; // Status from image-reading functions
  tft.initR(INITR_144GREENTAB); // initialise ST7735S chip, green tab
  tft.setTextWrap(true); // Allow text to run off right edge
  tft.fillScreen(ST7735_WHITE);
  tft.setTextColor(ST7735_BLACK);
  Serial.print(F("Initializing SD card..."));
  if (!SD.begin(SD_CS)) {
    Serial.println(F("failed!"));
    for (;;); // Loop here forever
  Serial.println(F("OK!"));
  Wire.begin();
  Teclado.init();
  Serial.print("Testing keypad/PCF8574 I2C port expander arduino lib\n\n");
  char Key = Teclado.get_key();
  if (Key) {
    Text[Ind] = Key;
    Ind++;
    tft.setCursor(1, 36);
    tft.println(Text);
  reader.drawBMP("/image1.bmp", tft, 0, 0);
  delay(3000);
  reader.drawBMP("/image2.bmp", tft, 0, 0);
  delay(3000);
  reader.drawBMP("/image3.bmp", tft, 0, 0);
  delay(3000);
The use of delay() in your sketch is the problem. For a simple demonstration of how to avoid that issue, check out this tutorial:
For a more detailed tutorial, see this:
http://forum.arduino.cc/index.php?topic=223286
Thanks a lot Pert, I followed your advice replacing the delay() statements. Unfortunately does not work, the ImageReader keeps "kidnapped" the display.
I attach the new code.
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#define ROWS 4
#define COLS 3
#define TFT_CS     26
#define TFT_RST    -1
#define TFT_DC     5
                     height = 0;
char Text[16];
int Ind = 0;
  Wire.begin();
  Teclado.init();
  if (Key) {
    Text[Ind] = Key;
    Ind++;
    tft.println(Text);
  Pause(3000);
  Pause(3000);
  Pause(3000);
void Pause(unsigned long WaitingTime)
  unsigned long Interval = millis();
  while (millis() - Interval < WaitingTime) {}
Oslaf:
No you didn't. You merely replaced delay() with your own blocking implementation that is no improvement. Please go back and study the links in my previous reply more carefully.
The whole point is that you want your loop function to run many times per second. There can't be an blocking code that halts the loop for long periods of time (anything much more than a few milliseconds being a long time for a microcontroller).
