Hello!
I want to build a GPS tracker with Arduino UNO and SIM808. I can see the received data, I create the file on the SD card but I can not write latitude and longitude in the file...
Here is the code I am running.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include "SD.h"
#include<stdio.h>
#include<string.h>
#define DEBUG true
// //input for the light detecting sensor (LDR)
// int LDR = A3;
//inputs and triggers for GPS
TinyGPSPlus gps;
SoftwareSerial ss (7, 8); // TX=, RX=
// digital pin 4 for the SD cs line
const int chipSelect = 4;
File logfile;// the logging file
char filename[] = "LOGGER00.CSV";
//data logger timing and other
#define LOG_INTERVAL 1000 // mills between entries
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
ss.begin(9600);
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
//Serial.println("AT+CGPSPWR=1\r");
//delay(100);
//Serial.print("AT+CREG?\r");
//delay(100);
//Serial.print("AT+CMGF=1\r");
//Serial.print("AT+CGPSINF?");
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
// char filename[] = "LOGGER00.CSV";
// for (uint8_t i = 0; i < 100; i++) {
// filename[6] = i/10 + '0';
// filename[7] = i%10 + '0';
// if (! SD.exists(filename)) {
// // only open a new file if it doesn't exist
// logfile = SD.open(filename, FILE_WRITE);
// break; // leave the loop!
Serial.print("Logging to: ");
Serial.println(filename);
logfile.println("date,time,lat,long,light");
#if ECHO_TO_SERIAL
Serial.println("lat,log,date,time,altitude");
#endif// attempt to write out the header to the file
Serial.print("AT+CGPSPWR=1\r");
void loop(void) {
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
getgps();
//here is GPS data (if I got it right)
while (ss.available() > 0)
{ gps.encode(ss.read());
File logfile = SD.open(filename, FILE_WRITE);
logfile.print(gps.date.value());
logfile.print(", ");
logfile.print(gps.time.value());
logfile.print(gps.location.lat(), 6);
logfile.print(gps.location.lng(), 6);
#if ECHO_TO_SERIAL
Serial.print(gps.date.value());
Serial.print(", ");
Serial.print(gps.time.value());
Serial.print(", ");
Serial.print(gps.location.lat(), 6);
Serial.print(", ");
Serial.print(gps.location.lng(), 6);
Serial.print(", ");
#endif
logfile.close();
// //Read light intensity
// float lux = 500/(10.72/(5-(photocellReading * 0.00488759))*(photocellReading * 0.00488759));
// logfile.println(lux);
// #if ECHO_TO_SERIAL
// Serial.println(lux);
// #endif //ECHO_TO_SERIAL
//write data to disk
// if ((millis() - syncTime) < SYNC_INTERVAL) return;
// syncTime = millis();
// logfile.flush();
void getgps(void)
sendData( "AT+CGPSPWR=1",1000,DEBUG);
sendData( "AT+CGPSSEQ=RMC",1000,DEBUG);
sendData( "AT+CREG?",1000,DEBUG);
sendData( "AT+CMGF=1",1000,DEBUG);
sendData( "AT+CSQ",1000,DEBUG);
sendData( "AT+CSMP=17,167,0,16",1000,DEBUG);
// sendData( "AT+CMGS=\"+40721071002\"\r ",1000,DEBUG);
String sendData(String command, const int timeout, boolean debug)
String response = "";
ss.println(command);
long int time = millis();
while( (time+timeout) > millis())
while(ss.available())
char c = ss.read();
response+=c;
if(debug)
Serial.print(response);
return response;
Can anyone help me please? I really need help, and I am running out of time...
I am looking forward to answer me! Thank you!
