Hi Everyone,
I have been trying to learn a bit more in depth Arduino by making a LoRa Tx/Rx to activate a water pump that fills a tank then switches off. Yes I have used various parts of different sketches and some of my own working out but I am really stuck on this one last problem. The Tx’r sends a message , the Rx’r gets the message, with start and end markers, parses the data and stores it in ‘receivedChars’. The sketch then prints the message received perfectly but it does nothing else! From line 104 on the Rx’r sketch does nothing.
If I have put the serial data received in an array (receivedChars) and it prints it to the serial monitor, why wont my IF statements work?
I am a pretty green programmer so go easy on me. I know there is a fair amount of copy and paste but thats how I learn.
I have been round and round in circles and its driving me mad now. I have a feeling the start and end markers may be throwing something out but I do not know why?
Any pointers would be much appreciated.
Cheers
Crumpy
Tx’r sketch-:
//Tank water level indicator with 433Mhz ESP32 & LoRa Tx'r
/*-----( Declare Constants )-----*/
#include <WiFi.h>
#include <SPI.h>
#include <LoRa.h>
#include <Arduino.h>
const byte ReedPinLow = 16; //byte is okay
const byte ReedPinHigh = 17; //make all pin definitions a variable
// GPIO5 -- SX1278's SCK
// GPIO19 -- SX1278's MISO
// GPIO27 -- SX1278's MOSI
// GPIO18 -- SX1278's CS
// GPIO14 -- SX1278's RESET
// GPIO26 -- SX1278's IRQ(Interrupt Request)
#define SS 18
#define RST 14
#define DI0 26
#define BAND 433E6 //433Mhz selected
/*-----( Declare Variables )-----*/
bool pumpOn = false;
void setup(){ /*----( SETUP: RUNS ONCE )----*/
WiFi.mode(WIFI_OFF);
btStop();
//Set pins as inputs and outputs
pinMode(ReedPinHigh, INPUT);
pinMode(ReedPinLow, INPUT);
while (!Serial); //If just the the basic function, must connect to a computer
LoRa.setSpreadingFactor(12);
LoRa.setSignalBandwidth(125E3);
LoRa.setTxPower(17, PA_OUTPUT_PA_BOOST_PIN);
LoRa.setCodingRate4(5);
LoRa.setSyncWord(0xF3);
LoRa.setPreambleLength(6);
//LoRa.enableCrc();
SPI.begin(5,19,27,18);
LoRa.setPins(SS,RST,DI0);
Serial.println("LoRa Sender");
if (!LoRa.begin(BAND)) {
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("LoRa Initial OK!");
void loop() {/*----( LOOP: RUNS CONSTANTLY )----*/
//Water low and pump on
if (digitalRead(ReedPinLow) && !pumpOn){
Serial.println("Bottom sensor triggered, Pump Start");
LoRa.beginPacket(); //Pump start Tx
LoRa.print("<empty>");
LoRa.endPacket();
pumpOn = true; //remember we started the pump
//Water high and pump off
else if (digitalRead(ReedPinHigh) && pumpOn){
Serial.println("Top sensor triggered, Tank Full Pump Stop");
LoRa.beginPacket(); //Pump stop code Tx
LoRa.print("<full>");
LoRa.endPacket();
pumpOn = false; //remember we turned off the pump
Rx’r Sketch-:
//Tank water level Rxr 433Mhz LoRa ESP32
#include <SPI.h>
#include <LoRa.h>
// WIFI_LoRa_32 ports
#define SS 18
#define RST 14
#define DI0 26
#define BAND 433E6
const byte numChars = 32;
char receivedChars[numChars]; //an array to store received data
boolean newData = false;
int relayPin = 16;
int relayState;
pinMode(relayPin, OUTPUT); // sets the pin as output for relay
relayPin = relayState;
while (!Serial); //if just the the basic function, must connect to a computer
Serial.println("LoRa Receiver");
while (1);
int packetSize = LoRa.parsePacket(); // try to parse packet
if (packetSize) {
Serial.print("Received packet :"); // received a packet
recvWithStartEndMarkers();
showNewData();
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (LoRa.available() > 0 && newData == false) {
rc = LoRa.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void showNewData() {
if (newData == true) {
//Serial.print("This just in ... ")
Serial.println(receivedChars);
newData = false;
if (receivedChars == "empty") //If this code received then turn on pump
Serial.println("Pump ON");
digitalWrite(16,HIGH); //Pump relay ON
relayState = HIGH;
delay(100);
if (receivedChars == "full") //If this code received then turn off pump
Serial.println("Tank Full - Pump OFF");
digitalWrite(16,LOW); //Pump relay OFF
relayState = LOW;
delay(100);
