fork/exec C:\Windows\system32\cmd.exe: Operation did not complete successfully because the file contains a virus or potentially unwanted software.
Error compiling for board ESP32 Dev Module.
Hi @Which version of Arduino IDE are you using (e.g., "2.0.1")? The version is shown on the window title bar and also in the Help > About dialog.
I ask for this information because I want to give you the appropriate instructions for the IDE version you are using.
Thankyou for replying, I'm using Arduino IDE 2.0.3 and Arduino IDE 1.8.9. Both show me the same error when i compile the code for ESP32.
I'm going to ask you to post some additional information that might help us to identify the problem.
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
- Select File > Preferences from the Arduino IDE menus.
- Check the box next to "Show verbose output during: ☐ compilation".
- Click the OK button.
- Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
- Open a forum reply here by clicking the Reply button.
- Click the
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the compilation output into the code block. - Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt
file and then attach that file to a reply here:
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txt
format. - Open a forum reply here by clicking the Reply button.
- Click the "Upload" icon (
) on the post composer toolbar:
- Select the
.txt
file you saved. - Click the Open button.
- Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt
file onto the post composer field to attach it.
