Greetings,
I have returned to square one because I am fairly certain that something is not set correctly in my IDE. I am now trying to run a simple blink sketch on a XIAO ESP32C3 (the sketch provided by Seeeduino) and I get errors in the verbose mode that I cannot interpret. If someone could examine these and suggest what might be wrong, I would greatly appreciate it. Every time I try to bring a new (to me) XIAO processor online it is nothing but heartache and mental anguish. The list of errors follows the code.
[code]
// define led according to pin diagram
int led = D10;
// initialize digital pin led as an output
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); // turn the LED on
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off
[/code]
Sketch uses 222884 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13532 bytes (4%) of dynamic memory, leaving 314148 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM4
Connecting...
Chip is ESP32-C3 (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 34:85:18:07:c8:3c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
A fatal error occurred: No serial data received.
