I can't burn the bootloader
When trying to burn the bootloader, I get the following error.
Arduino: 1.8.1 (Windows 10), Board: "Arduino M0 Pro (Programming Port)"
C:\Users\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino/bin/openocd.exe -d2 -s C:\Users\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino/share/openocd/scripts/ -f C:\Users\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11/variants/arduino_mzero/openocd_scripts/arduino_zero.cfg -c telnet_port disabled; init; halt; at91samd bootloader 0; program {{C:\Users\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11/bootloaders/mzero/Bootloader_D21_M0_Pro_150427.hex}} verify reset; shutdown
Open On-Chip Debugger 0.9.0-gd4b7679 (2015-06-10-22:24)
Licensed under GNU GPL v2
For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
debug_level: 2
Info : only one transport option; autoselect 'swd'
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: JTAG Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 01.1F.0118
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 500 kHz
Info : SWD IDCODE 0x0bc11477
Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x81000000 pc: 0x000058fc msp: 0x20007fb0
xPSR: 0x81000000 pc: 0x000028f4 msp: 0x20002c00
** Programming Started **
auto erase enabled
Info : SAMD MCU: SAMD21G18A (256KB Flash, 32KB RAM)
Info : Padding image section 0 with 3196 bytes
wrote 32768 bytes from file C:\Users\nikal\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11/bootloaders/mzero/Bootloader_D21_M0_Pro_150427.hex in 8.470639s (3.778 KiB/s)
** Programming Finished **
** Verify Started **
Warn : target was in unknown state when halt was requested
Error: error executing cortex_m crc algorithm
Runtime Error: embedded:startup.tcl:454: ** Verify Failed **
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 498
at file "embedded:startup.tcl", line 454
Error while burning bootloader.
Any way to fix this?
Hi @98ahni,
I have the same problem..
Did you find the solution?
