I can't configure the mkr1000 encryption chip.
This erased my idea of buying Uno WiFi.
This may violate the original intention of Arduino.
After all, the board is already expensive.
If you're concerned about the limits of Arduino Web Editor and you don't want to pay for the Maker Plan, just use the free open source Arduino IDE:
  • Unlimited compilation time
  • Unlimited sketches
  • Unlimited libraries
  • Support for all 3rd party boards
Or if you prefer a command line interface, use free open source arduino-cli:
They both support the Uno WiFi Rev2. Arduino Web Editor is just one option available to you.
gaebel90:
I have the same problem with the MKRWIFI1010 on the arduinocreate site. Everything was installed flawlessly till Ive reached the crypto chip part. Ive tried all my USB 2.0 connections on my laptop without success.
I have the latest Firmware version installed according to WifiNina, which is 1.2.1.
The Agent version of the plugin is 1.1.88-83043b2. I use Win 7.
Please help.... :frowning:
I didnt use it with the foam on. Not a single pin is used at the moment, but beforehand, I had a sensor connected while trying to configure the crypto chip. CreateAgent plugin is installed, see the quote beforehand to see the installed version. I'm using the Chrome browser.
Only the upload of the Blink script creates problems.
Ive uploaded the Blink script and it works, but still I get an error message:
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkrwifi1010 -build-cache /tmp -build-path /tmp/072226262/build -verbose -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -libraries /tmp/072226262/custom -libraries /tmp/072226262/pinned /tmp/072226262/Blink
Sketch uses 12096 bytes (4%) of program storage space. Maximum is 262144 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[COM4 COM7 COM9]
Touching port COM9 at 1200bps
Set DTR off
Flashing with command:C:/Users/Customer/.arduino-create/arduino/bossac/1.7.0-arduino3/bossac.exe -i -d --port=COM9 -U true -i -e -w -v C:/Users/Customer/AppData/Local/Temp/arduino-create-agent054067020/Blink.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.837 seconds
Write 12256 bytes to flash (192 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[========== ] 33% (64/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[==================== ] 66% (128/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[==============================] 100% (192/192 pages)
SAM-BA operation failed
done in 0.081 seconds
Verify 12256 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 2597
checksumBuffer(start_addr=0x3000, size=0x1000) = 4ce4
checksumBuffer(start_addr=0x4000, size=0xfe0) = 8ada
Verify successful
done in 0.016 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
I’ve used my third usb-port Ive completely forgot about and now there was no more samba issue on arduino create, when Ive used the online editor… the compiling was successfull (green verbose output; see attachement). There is also no samba issue, when I use the Arduino IDE on my PC.
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkrwifi1010 -build-cache /tmp -build-path /tmp/161130482/build -verbose -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -libraries /tmp/161130482/custom -libraries /tmp/161130482/pinned /tmp/161130482/Blink
[COM4 COM8]
Touching port COM8 at 1200bps
Set DTR off
Flashing with command:C:/Users/Customer/.arduino-create/arduino/bossac/1.7.0-arduino3/bossac.exe -i -d --port=COM8 -U true -i -e -w -v C:/Users/Customer/AppData/Local/Temp/arduino-create-agent750657226/Blink.bin -R
Set binary mode
chipId=0x10010005
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
done in 0.838 seconds
done in 0.073 seconds
Verify successful
done in 0.012 seconds
CPU reset.
Now, I get a timeout, when I want to configure the crypto chip… see the attachement. The whole thing is stressing me out so much. I dont know what the issue is…
Your MKR WiFi 1010 has been set up correctly and added to your Device Manager!
You may now go to the Web Editor and use the Network Monitor via Cloud.
As long as your code includes the WiFi configuration and the ArduinoIoTCloud Library , you'll be able to control your board from anywhere.
What. It just worked suddenly after 2 hours of trying around. Maybe the new USB-port helped, BUT it also took a few times till it magically worked....
